Derbo's EX hatchback commuter
Civics4Ever
Rally Red EXT
Gene
Nice. But all the $$ you put in, you could have bought a CTR.
derbo904
derbo904
Keeper of Blinky lights
Bay Area, CA
17 FK7 | 11 E90M3
I don't get this comment. Where is all this $$ I put in? I barely put in $2k worth of parts outside of maintenance (I have a spreadsheet). Clearly a $23k MSRP EX will become a $36k CTR with $2k worth of parts. ROFL.
KYRGYZ
Bay Area
16 Civic LX, 18 Model X 100D
I noticed you in bay area, is there a way for you to help me with ex-l steering wheel install?
dt17
Daryl
Bangkok Thailand
Civic hatchback turbo 2017
Did you managed to weigh the wheels before and after? You went from 17" to 18"?
Since my tires were starting to go, I figured I start hunting for a set of OEM wheels. I always wanted a sport hatchback but I wanted the EX features. I posted a few threads up to WTB touring, Si or Sport wheels. Luckily a local member here just got an Si and was about to take them off. We setup a deal and I picked up a set of Si wheels!
I was pleasantly surprised that the wheels were made by Enkei.
I really like that it is the polished versions from the sedan/coupes instead of the gunmetal ones. This seems to brighten up my hatchback as pure black darkness was a bit much. :)
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
Unfortunately no.
Based on some searching:
2017 Civic 4dr EX Turbo wheel is rated at ugly 28.79lbs.
Civic Si wheels are 42700-TBF-A91 and only found on Si cars, 28lbs. and produced by Enkei.
That said, the wider tire is heavier and I did lose about 1-2mpg from the car..but it looks sooo much better. :)
Angelortiz15
Angel
Honda Civic Hatchback 2019
Today I tackled the steering wheel swap. It feels so much better that plastic thing not to mention looking a lot better.
Notes:
-The steering wheel bolt is on there good. 10mm Hex socket + a huge breaker bar did the trick.
-I bought two new airbag bolts and steering wheel bolt because they have dry green locktite on there. I would assume its only a one-time use bolt. They aren't too expensive at $11 for 3 bolts.
-When the steering wheel is removed, I saw there was two lines on the steering column splines. They matched two lines on the steering wheel. My guess is that it was marked to help alignment be simpler. It certainly helped me since the rotating black piece with the white peg could freely rotate when the steering wheel was off.
-When installing the battery again, the dash will light up like a christmas tree. A simple test drive will reinitialize everything and the lights will go away.
where Did you get the steering wheel?
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
Honda Civic 10th gen Derbo's EX hatchback commuter ZKFnNYo
Added an AFE air filter at 123,707 miles.
Nothing to report, just running like a champion workhorse! :)
Honda Civic 10th gen Derbo's EX hatchback commuter Uu3l28D
Doing workhorse stuff like carrying my rims for my M3.
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
I finally decided to just give in and buy OE LED headlights. I'm currently researching how to fix hyperflashing and looking for a fairly clean setup. I already bought a harness from ebay but the resistors included were not wired in already. I haven't decided if I use it or replace it with another harness yet.
Honda Civic 10th gen Derbo's EX hatchback commuter defdb60d-ff87-4457-afa9-8af33cb9ca78
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
## LED Headlight install
I've been wanting to buy LED headlights for awhile now and finally found a set of used OE headlights for a decent price. These were the 2019 ones so hopefully it has less glare than the older version.
LED headlights use 2 plugs, a main plug for hi, lo, turn, and another plug for the DRL. I purchased a harness to minimize splicing. Unfortunately the harness I purchased on Ebay did not have the resistors for the turn signal hyperflashing wired in. I had to splice them myself which was unfortunate since the Ebay listing said no splicing required. It wasn't the end of the world but more of an annoyance.
## Steps
  1. Unbolt the 1082190318390 clips for the bumper, 2x 5mm hex, 2x10mm
  2. Remove the bumper, unplug the fog lights
  3. Unbolt the headlights and unplug them
  4. Swap the headlight bracket to the new LED headlights
  5. Test harness before installing. Check low, high, turn, DRL.
  6. Reverse order install.
Honda Civic 10th gen Derbo's EX hatchback commuter XaUoflV
Honda Civic 10th gen Derbo's EX hatchback commuter sFe4kRG
Honda Civic 10th gen Derbo's EX hatchback commuter x4LWIK4
Honda Civic 10th gen Derbo's EX hatchback commuter dl2kmSB
Output is wider than my old HID drop in kit but not as far. I haven't driven it much besides to wall in the picture to get it aligned. Overall, I'm happy with the setup and building my own weirdly spec Civic Hatch.
If you made it this far to this post. Congratulations. Till next time.
arsh88
Wisconsin
2018 Honda Civic Hatchback EX
This is pretty dope. I think i'm going to have to finally get my pics together and post everything I've done so far.
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
Thanks man! It was more of a journal for myself to just timeline items. It is kind of a habit I've done over the years for my previous cars. Happy someone got enjoyment out of it.
