Dashboard cracking?
eXultanCe
eXult
'16 Honda Civic EX-L
Car isn't even 3 months old, and I'm already seeing this part of the dashboard crack...I even have a sunshade at all times.
Anyone else notice the same issue?
Honda Civic 10th gen Dashboard cracking? 20161022_162647
Honda Civic 10th gen Dashboard cracking? 20161022_162639
Honda Civic 10th gen Dashboard cracking? 20161022_162603
Honda Civic 10th gen Dashboard cracking? 20161022_162558
Civics4Ever
Rally Red EXT
Gene
Illinois
Looks like fading. Did you ever clean or dress it with any products?
eXultanCe
eXultanCe
eXult
Not seeing anything bruh
I marked two pics in red whats actually cracking, yellow whats the normal pattern.
Never. The most that touched that was a drop of water used with a microfiber cloth to remove fingerprints.
Sorry but this is just nitpicking...
Don't see how its nitpicking if its actually cracking with less than 3 months.
that the oem pleather texture.
The OEM texture is marked in yellow in the pictures. The texture is a horizontal "scratch" looking pattern, whereas the areas I marked in red that are actually cracked have a different pattern as you can see.
Honda Civic 10th gen Dashboard cracking? 1
eXultanCe
eXultanCe
eXult
Yes, always. Neither where I live or where I work have a garage.
inv4zn
Vancouver, Canada
'16 Touring
Could it be UV damage? That part of the dash is obviously some sort of plastic with a vinyl (maybe) overlay, so it's probably that?
I think if it really bothers you you can buy more vinyl (3M Carbon Fibre, or something) and cover it up?
It looks like there's not much you can do, especially if you have no choice but to park in sunlight/heat
eXultanCe
eXultanCe
eXult
Oh yeah, definitely. I did plan on getting some of the colored vinyl for inside. I was just surprised how easily it has started to crack.
Now to gain some courage to put the vinyl there. Worried I'd do more damage than it already has lol
inv4zn
Vancouver, Canada
'16 Touring
It's essentially a large sticker so it's not too hard. Interior pieces even more so.
GL!
eXultanCe
eXultanCe
eXult
GL!
My fear is messing with the heat gun. Based on what other people had said, they needed to use one to stretch the vinyl out.
inv4zn
Vancouver, Canada
'16 Touring
That's usually for harsh curves for body panels, etc. That dash piece is very flat so no issue. You can use a hair-dryer as it's less hot than a heatgun.
eXultanCe
eXultanCe
eXult
That should make it easier. I'll try that then. Have you done it to your car?
