Dash lights on after WOT
B_real
Bento
Netherlands Antilles
2017 Cosmic Blue Civic Touring
I was driving home a 30min ago when a guy with a GTI wanted to race with me. I was on ktuner map 1 and switch to map3 (OTF). When i did floor it a couple of seconds after my tire starts spinning i felt a throttle pull back and all the light in my dash came on. i pulled over and turn the car off and the on (2x) but all the lights stayed on (power steering system problem, brake hold system problem, VSA problem, hill start assist problem, RDM system problem, barke sysrem problem, emission problem, check engine). when i went to change back to map 1 i saw that the car was already in map 1.
So a arrive at home and scan the car a got these error codes:
- cylinder 1 misfire, cylinder 3 misfire, random and multiple cylinder misfire.
- fuel rail pressure high.
the car has 22742miles on it.
anyone knows how to remove these lights and what could have happened (870 miles with the car flash, drive mostly in map1 and eco on)
A few points.
1. You may want to pull up the actual error codes and post them here.
2. Those electronic errors you see may disappear after a few drive cycles.
3. When you turn the car off, it will revert to Map 1 unless you leave KTuner plugged in all the time.
B_real
B_real
Bento
A few points.
1. i will check the error and post them.
2. ok..i will check this tomorrow.
3. ok thnx for the info , the ktuner was unplugged from the car.
OhMyItsKev
Kevin
Texas
2017 Civic Sport Touring
Not sure if it'll help but... try disconnecting the battery, waiting a few minutes, then reconnecting it. You'll have to drive about 2 miles and then the lights should go away. If not, it might have been a different issue.
I had the same issue before I had a Ktuner and all my dash lights came on when I did a big pull.
B_real
B_real
Bento
@OhMyItsKev i did disconnect the battery and reconnect it back the next day and all the lights were gone also scan the car no error codes.
last night i did try again with map2 (racing with a 350Z) no lights no errors, then i did try map 3 no lights no errors.
if this happened again i will take picture of the codes and share it here.
thank you all for the support.
Pbergmann
Pete
Arizona
2019 Civic sedan EX-L
How about not racing others. Google street racing fails.
Sorry about being a wet blanket.
OhMyItsKev
Kevin
Texas
Don't think OP was asking for your opinion about his racing.
