samaximuss
Hey guys I just ordered D2's... do you think I'll need something to avoid from getting a warning light due to the suspension.
You should be good if it’s just the springs. You only get the light when you replace your suspensions with coilovers.Hey guys I just ordered D2's... do you think I'll need something to avoid from getting a warning light due to the suspension.
Cheesus you're the bomb, thank you for confirming that for me... I'm stoked and can't wait to put them on. Do you have experience with these springs?You should be good if it’s just the springs. You only get the light when you replace your suspensions with coilovers.
You are not gonna regret it. D2 springs gave my car the drop I wanted. Like what lurker said if you are worried about the wheels rubbing don’t go wider wheel. I have 9.5 wheels on and it rubs but I think getting a smaller tire will fix it. Post pic and let us know what you think after you get it installed.Cheesus you're the bomb, thank you for confirming that for me... I'm stoked and can't wait to put them on. Do you have experience with these springs?
Thank you guys, I feel a lot more comfortable now! Springs should arrive by the weekend, do you know more or less what tech shops usually charge to install them ($150 - 250)?
PRL quoted me like $400 to put springs on. Not sure how that compares to other shops.Thank you guys, I feel a lot more comfortable now! Springs should arrive by the weekend, do you know more or less what tech shops usually charge to install them ($150 - 250)?
Car looks awesome btw, super clean
I was gonna install myself but I got lazy so I paid $180 for installation.Thank you guys, I feel a lot more comfortable now! Springs should arrive by the weekend, do you know more or less what tech shops usually charge to install them ($150 - 250)?
That's what I was thinking... $150 - 250 max. I have some buddies in Miami that are deep in the car scene so I've reached out to see if they can hook me. I appreciate all of the information guys, this helps tons. Can't wait to have my current setup complete then post pics and on to the next mod LOLI was gonna install myself but I got lazy so I paid $180 for installation.
i heard it's a common issue but luckily mine was good when i had 'em check. I know a couple people that has this issue. Also I was told that the cv boot is on backorder at the momentHas anyone had concern about the CV boots getting torn on install? Seems like a bunch of guys have blown CV boots not too long after putting springs on. The consensus is that they get nicked when the front struts are taken out/put back in.
Yeah I’m just hesitant because of that. I don’t want to pay a ton to have it done but I also don’t want an issue.i heard it's a common issue but luckily mine was good when i had 'em check. I know a couple people that has this issue. Also I was told that the cv boot is on backorder at the moment
I actually had mine tear a tiny bit on the front passenger side. Small enough though that I could seal with some duct tape. But wouldn’t have found it if I didn’t inspect it.Yeah I’m just hesitant because of that. I don’t want to pay a ton to have it done but I also don’t want an issue.
When did u find it out? i have mine thats leaking for 4 days now but not leak leak just tiny leaks.I actually had mine tear a tiny bit on the front passenger side. Small enough though that I could seal with some duct tape. But wouldn’t have found it if I didn’t inspect it.
Mine came from friction between my cv boot and the knuckle assembly when trying to get the strut out. If you’re careful, you won’t tear it. Just gotta pay attention to how you're shifting everything.
