atomcycom
I have data logged my custom tuned calibration. The A/F should be ok.Have you tried to datalog more than once? Datalogs can get corrupted from time to time
Just testing whether the can data logging. Will try WOT tmrw.you didnt do any WOT runs on the logs.
this would be so much easier for you if you just ask your tuner to email you with a updated TQ calibrationJust testing whether the can data logging. Will try WOT tmrw.
Yes will check with my tuner regarding this. Btw, i have did a datalogging with some WOT.this would be so much easier for you if you just ask your tuner to email you with a updated TQ calibration
It's impossible to tell if the numbers are "off" just using one dyno session. The reason is that each dynos vary quite a bit and there is no general formula that will tell you how to estimate flywheel horsepower from dyno #s. You would need to have detailed knowledge of the particular dyno. From your session, if CAP1 is from before the tune and SAP4 is from after the tune, then you made some awesome gains! Most likely you are making around 215 to 225 hp at the flywheel, if my assumptions are correct.Hi Guys,
Just recently got the Civic 1.5t CVT (AUS model) custom tuned with hondata flashpro, car is stock other than a Mishimoto intake.
I'm a newbie when it comes to tuning etc, but wondering if my numbers off the dyno are on par with what others are getting?
Sorry I may have worded myself incorrectly but i meant "from" the dyno not that my numbers looked "off". CAP1 is the stock dyno numbers vs SAP4 after the tune.It's impossible to tell if the numbers are "off" just using one dyno session. The reason is that each dynos vary quite a bit and there is no general formula that will tell you how to estimate flywheel horsepower from dyno #s. You would need to have detailed knowledge of the particular dyno. From your session, if CAP1 is from before the tune and SAP4 is from after the tune, then you made some awesome gains! Most likely you are making around 215 to 225 hp at the flywheel, if my assumptions are correct.
Just curious as it was mentioned in this thread others were getting 250-280 lb-ft torque, looking at my graph I'm getting 278 Nm after the tune which equates to 205 lb-ft if I'm interpreting it correctly?I should point out that those values in the CVT TQ limitation table are in lb-ft, not Newton Meters (Nm). The factory tune will put out more than 250 Nm, which equates about 184 lb-ft of torque.
What is important is the gain (difference) in the before and after dyno. You can't accurately compare your dyno results to what others have gotten on other dynos. Most likely the dyno you used just reads lower than average.Sorry I may have worded myself incorrectly but i meant "from" the dyno not that my numbers looked "off". CAP1 is the stock dyno numbers vs SAP4 after the tune.
Pretty big difference if thats the case.. is my tune too "conservative"? sorry if it's a silly question..
Ok good to know, can definitely feel the difference with the tune which is awesome. Thanks for the insights!What is important is the gain (difference) in the before and after dyno. You can't accurately compare your dyno results to what others have gotten on other dynos. Most likely the dyno you used just reads lowers than average.
