CVT not shifting from 0-125 at full throttle
Stephen
Bone Stock
Stephen
Shreveport, La
2019 Civic Sport Hatchback CVT
Tonight I experienced a “glitch” maybe, not sure what to think. I have a 2019 Civic Sport Hatchback CVT and under full throttle it went to 6000+RPM from 0-125 MPH without shifting. It just sat at the same RPM to top speed. Any clue what happened? Hopefully the YouTube link shows up, idk still a noob
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
This has to be a joke. In case it isn't: you posted a video about a Civic Sport Hatch in the Type R section. The CVTs behavior is perfectly normal. It goes to max power and stays there.
jayy_swish
Jay
That’s technically how a CVT operates there’s no gears to shift like an automatic the only reason you feel “shifting” is because the automakers added those due to the fact that people complained about a CVT holding out the RPMs as a constant rpm and they thought it was broken because it wasn’t shifting. Even though it’s not “shifting” the CVT should be doing it’s job of going through it’s pulley gear ratios.
Stephen
Stephen
Bone Stock
Stephen
Shreveport, La
Didn’t mean to post it in type r (still noob) so I’ll delete it in the morning hoping for an actual helpful reply before then. Unfortunately it is far from normal. The cvt has preset shift points that were hitting before this video was recorded but now it stays at the same rpm through the mph range
Stephen
Stephen
Bone Stock
Stephen
Shreveport, La
I’m just worried about the change in the preset shift points
jayy_swish
Jay
Does it hit them in drive ? And since you have a sport try it with paddle shifters, if it’s hitting the shift points then you should be fine. Try flooring it in drive and seeing if it has shift points
Gruber
Mark
TN
There are no preset shift points. There are no shifts. It's a CVT. However, if you floor it like you are trying to beat a 0-60mph time, it may feel like it's shifting, because they programmed it this way. If you accelerate any slower than just flooring it, it will not do any shifts.
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
Barry
Allen
Honda civic
Hmmm that usually happens in L gear . ..there should be simulated gear shifts in s
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
Yeah, mine had simulated shifts when i had my 2016 EXT in S mode.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
The CVT does have preset shift points, but those shift points are going to be somewhat arbitrary unless you drive the car in sequential mode (with paddles). At WOT, this is perfectly normal behavior for the CVT to Continuously Vary the Transmission’s gear ratios to keep the motor at peak power to maximize power output to go the fastest.
Stephen
Stephen
Bone Stock
Stephen
Shreveport, La
Did the same thing in drive, I’ll try the paddle shifters momentarily
Stephen
Stephen
Bone Stock
Stephen
Shreveport, La
Update: Head mechanic at Honda said that’s a normal characteristic. Sometimes the computer wants to play right
bbeem
Ben
Iowa
But which way was faster though?
