- Shawn
- Nov 18, 2020
- 11
- 104
- 28
- Canada
- Honda
- Banned
- #16
Idk, I've done pulls with full throttle at the exact spot on the road and its still unpredictableThe perceived "unpredictability" of the CVT logic is just the result of relatively complex programming of the powertrain. It uses what could be called some sort of heuristics or AI. The program is trying to guess the driver's intentions based on a multitude of parameters. Such as gas pedal position and rate of change but also a dozen others. Since you are not aware of all the parameters, you may have impression like it's random. It may depend on exactly how abruptly you are mashing the gas, what were you doing a moment ago, what has been the speed of the car, the load on the engine, the gearing, going straight or turning or turning sharp or going uphill, etc. So the algorithm is trying to guess if you are just trying to get a burst of power for passing, or trying to beat a 0-60 time, and it may or may not take your "pedal to the floor" literally, as a "go to the redline" request.
You probably have the best chance of getting the simulated shifts when you do a 0-60 from a dig or very slow roll. Otherwise, the car will do the typical automatic transmission "kickdown" procedure, assuming you are trying to pass, not just trying to get to the redline in a hurry. How the gearing will actually change (whether it's enough to just increase the rpm and boost, or an actual "kickdown" is necessary) will depend on whether the computer judges the acceleration is enough or not.
We are dealing here with an actual computer program, but even in older mechanically controled transmissions the kickdown behavior could be quite complex:
https://www.hotrod.com/articles/pit-stop-automatic-trans-kickdown-cables-really-needed/
So the TL;DR is: it's not unpredictable or random -- it's just more complex than you think. In the CVT civic, optimizing it for a regular naive driver takes priority over a racing/testing/joy-driving assumption.
That's what "automatic" means: it does it for you, but you lose some control.
