Custom 23psi tune for cvt
jaja340
Maryland
2016 Civic Ex-L
Does anyone have knowledge on how to adjust the boost tables correctly to achieve 23psi on the cvt? I've messed with BBG and plan on keeping first a good bit lower but when i change the boost target to 23psi im not able to achieve any more than the stage 2 +6psi tunes 20-21psi.
Wild guess here... what is in the final column of your final boost table?
jaja340
jaja340
Maryland
2016 Civic Ex-L
  • #3
The final column says 22.5 but when im WOT it will quickly spike to 22 or 23 then level out at around 21psi.
dc2turbo
usa
civic,teg
you need to set it to something higher like 25psi on the last column of final boost target
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
This table will limit you, as described in the help. You need to change the entire column, including the header, to the boost level you want to see as a max. Then you'll also need to change the boost target tables separately.
