Cusco (and probably any other brand) Strut Tower Bar Install
Z06Chris
C. Yi
Atlanta, GA
2019 Honda Civic Type-R
This probably applies to installing any strut tower bar so I figured I'd make a post with sizes and torque specs.
*Sorry not all sizes will be Metric*
First remove the nuts on the strut. They're size 14mm.
Put away the black ring plates as these will not be re-used.
Install Cusco or whatever strut tower bar.
Use factory nuts and torque them to 46 ft lbs.
The Cusco instructions say to tighten the strut nuts to 32 ft lbs but that seemed low so I went with factory specs.
Once those are torqued, torque the bolts on the strut bar itself to 42 ft lbs using a 11/16th socket and 5/16th Allen wrench.
You're all done.
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install DSC03863.JPG
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install DSC03865.JPG
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install 20190820_153817
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install DSC03868.JPG
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install DSC03872.JPG
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install DSC03870.JPG
Tim818
King Of The ‘Ring
Texas
2006 Civic EX, 2018 CTR
You forgot that you have to park on a flat surface while doing this, I need to hurry up and install my Beatrush titanium strut bar.
Honda Civic 10th gen Cusco (and probably any other brand) Strut Tower Bar Install 65845CFF-4B01-4337-A205-DEC5F88ADE88
Z06Chris
Z06Chris
C. Yi
Atlanta, GA
Ah yes. Don't do this when your suspension's uneven lol that could be real bad but hopefully everyone's got enough sense to do it on a flat surface.
bushido69
Hiro
so cal
2020 SGP Type R, 2012 Toyota Tacoma TRD Sport, 2012 Mazda CX-9 GT, 2002 Lexus ES300
You're all done.
Still waiting for mine from evasive.
j_limitz
Justin
Toronto, Ontario, Canada
2020 Honda Civic Type R - Championship White
I wonder if you remove the alignment pins if it still fits properly since the shock is moved inwards
ayau
Subaru
The Cusco bar is oblong, but the Beatrush is just a regular circle. I'm guessing removing the pins for the Beatrush may not work.
Warpspeed
Noel
Norcal
2003 Evo8, EF Civic Si, and 2020 CW Civic Type R
Exact same strut bar I got awhile back. I think it only cost me $130 or $140 when it was on sale. Just make sure the chrome nut in the Middle doesn't rub on the bar.
dwag0588
David
Chattanooga, TN
2020 CW CTR, 2014 Mazda CX-5, 2006 NC Miata, 2018 Silverado 5.3 (work)
Any noticeable handling difference with strut tower bars on this car? Or is this more for looks? No judgement either way, just curious.
Z06Chris
Z06Chris
C. Yi
Atlanta, GA
Mainly for looks. I don't think any car has ever had a lot of benefit from a strut bar.
Type_MBN
every dream has a beginning
Peter
Cerritos, CA
'05 AP2, '21 CW FK8, '08 USF40
Thanks for this write up! :headbang:
Saved me some time!
