really i should call amazon thenOnlinecarstereo.com shipped me the Punch for $99
thats the amount i got it forWhen I priced amazon 2 weeks ago it was $118 or so..
The amazon link above is $102 shipped..
looks nice how much was the ampOP, thanks for the post and inspiration. I also removed the factory sub and replaced with the same rockford sub. I also added sound deadening to the factory enclosure and all the surrounding areas. The sub is powered by a PBR300X1 and the sound is amazing! The amp fits in the the foam compartment under the floor with room to spare. Added a PC fan to help with heat.
Totally different in the car now...the bass is bumping so hard nowlooks nice how much was the amp
Yes, 10” jl audio sub in a one cubic ft box...12”x12”x12” runnin 2ohm off the factory amp. Better but not bass heavy.Have anyone just replaced the sub with out an added amp? Does it sound any better?
The factory amp is 4 ohm, no? I just want to replace with an 8" so I keep all the trunk space.Yes, 10” jl audio sub in a one cubic ft box...12”x12”x12” runnin 2ohm off the factory amp. Better but not bass heavy.
I know this has been for a while. but, can you tell me where you got the power supply for the new amp? is the factory amp supply nearby? or you did wire all the way from the battery? thanks!OP, thanks for the post and inspiration. I also removed the factory sub and replaced with the same rockford sub. I also added sound deadening to the factory enclosure and all the surrounding areas. The sub is powered by a PBR300X1 and the sound is amazing! The amp fits in the the foam compartment under the floor with room to spare. Added a PC fan to help with heat.
You need to wire the amp to the battery. Don’t forget to add a fuse.I know this has been for a while. but, can you tell me where you got the power supply for the new amp? is the factory amp supply nearby? or you did wire all the way from the battery? thanks!
got it. thanks!You need to wire the amp to the battery. Don’t forget to add a fuse.
