CTR Rev Matching and Emissions Issues w/Check Engine light.
RP2000R
WA
21 Porsche GT4, 20 Civic Si, 15 Lexus IS350 RWD
Can you guys that have had the issue share your badge number?
All-Knowing
Hondaville
NSX
No reports about this in UK FK2R forums.
I just checked that connector in my car. It looks different in my FK2. The connector is smaller.
Guess it's not the "same" as earlier mentioned...it doesn't take many differences to induce different vibrations and such...
Hondanatic
Snellville, GA
2014 Acura ILX 2.4 - 1991 CRX SI LS/V
My baby has officially joined the club. Currently at the dealer. Wish me luck!
CTR #380
My estimated time for wiring harness arrival is July7-10. Just be patient brother and ask that no one but that 1 Master Tech touches your car. Mine was placed in a bay all the way to the back away from the usual traffic of cars going in and out and is up on the lift so no one can even just go by and mess with it.
RP2000R
WA
Hoping someone can come up with a preventive fix or a way to fix this before it happens.
Can we check the plug and see if the wires loose?
Re pin it if loose?
Solder connection?
Anyone have any ideas?
Also guys with the issue please continue to post car number!
PwrOfDreams
It ain't a Type R then it ain't a tight car
None
Other
Would this happen to all type r owners. Is this what to be expected? Mines was built 5/17'
tacthecat
Cheshire, MA
'12 Civic Si Sedan
Hoping someone can come up with a preventive fix or a way to fix this before it happens....!
It can likely be done by anyone who is half tech-savvy.
Just be aware that this is almost guaranteed to be a recall item (EPA/emissions related) so make sure it's done "discretely".
Recrimping is first choice so as not to expose electronics to stray current/voltage and toasting the ECU.
If you chose to solder, unless you're doing it the old-school way, disconnect cable at both ends - doubtful this can be easily done.
Ruckus
Wisconsin
2017 Civic Type R. 2012 Honda Ruckus. 2001 civic sedan. 2012 accord sedan.
Re pin it if loose?
Solder connection?
personally i cut the zip tie off the connector to give the wires some slack, i think they were being pulled too tight. gave the wires the tug test and they are good for now. just waiting for the recall to come out
hondatech nate
Ridgeline
Plenty of emissions related things never become recalls. Most likely this will become a bulletin but may become a recall due only to the fact that this is a flagship car. Most of the time if it doesn't pose a safety threat then it won't become a recall.
