CTR REAR SWAY BAR INSTALLED...ADDITIONAL INFO FOR YOU GUYS
CyberCT
Nazareth PA
2018 Civic SI Coupe
The CTR RSS does not cause too much oversteer. To me it feels very balanced, cuts down on understeer greatly from stock Si RSS. Honestly I was hoping for more oversteer but even with t/c completely off, it’s hardly there and if I am able to induce any it is very minimal.
One thing's for sure, I absolutely don't want to rotate the car (get the rear to step out due to oversteer) in any situation. I just want to reduce understeer a bit without also upsetting the stability over bumps, on highways, etc.
L8apex
Southern Cali
2018 SGP Sport
This. Keep in mind that changing out the rear swaybar will not turn your civic into an oversteering monster. At best, it’ll bring that oversteer more within reach. Swaybar stiffness for the most part affects steady state cornering attitude. A lot, I mean a lot of driver input will influence over- and understeer situations. With the correct tires, the ideal line, and optimized alignment settings, you can make a car handle corners extremely well. Swaybars are the last thing you adjust as far as tuning, and generally set to the softest settings if the springs and shocks are properly sorted.
And no, you should not ever preload your swaybars. It does not add stiffness.
CyberCT
Nazareth PA
2018 Civic SI Coupe
So to install the rear sway bar, are people lifting the rear up on jacks with the suspension and wheels suspended? Or are they driving up on ramps so the wheels and suspension are loaded together like they are typically?
L8apex
Southern Cali
2018 SGP Sport
I’ve installed and removed the CTR and the Whiteline rear bars with the wheels on ramps and the suspension at normal ride height, so it is possible to do that way. But I’m at stock height. It might be harder to do on a lowered car this way.
ycehcky
Matt
Virginia Beach, VA
2018 Civic Si
Has anyone installed the Accord Sport sway bar?
I think the Accord Sport sway bar is not as thick as the Si. I saw earlier someone commented on the weight thinking it was hollow, but I believe it is the same size as the civic sport bar.
Does anyone know if you can reuse the bushing "holder/bracket" or do you need the type r holders to fit the larger bushing?
L8apex
Southern Cali
2018 SGP Sport
The CTR brackets “appear” to be dimensionally the same as the Sport brackets. But when I removed the Sport brackets off the CTR bar/bushings, they were extremely tight. I installed the CTR brackets on the CTR bar/bushings, and when the time came to replace the bar with the Whiteline one, the brackets came off no problem.
Long story short, they look the same, and fit the same, but the CTR brackets must be slightly bigger than the Sport brackets, and I would recommend them when using the OEM CTR bar.
CyberCT
Nazareth PA
2018 Civic SI Coupe
For those that haven't done the install yet, I had no issue removing the old and installing the new swaybar with jacks holding up the rear (wheels hung suspended). With long arms and ratchets, half the work can be done without going under the car.
Remove the swaybar from the endlinks first, then unbolt the swaybar brackets. Take the brackets and bushings off of it. Then slide the swaybar out from one side of the car (might take a few attempts) THEN remove the endlinks on each side. Repeat the same process in reverse for installation.
Hope this helps.
Mr.Apex
Dylan
Bay Area Ca.
2020 Si Sedan
Here are all the parts numbers in one tidy place for those who are looking into this like i was.
Type R Rear Sway Bar: PN:52300-TGH-A03
Type R Rear Sway Brackets: PN: 52308-TGH-A00 x2
Type R Rear Endlinks: PN:52320-TGH-A01 x2
Alternate Accord Sport 1 Piece Cast Endlinks: PN:52320-TLB-A0 x2
Actually, there's already (since 2017) a detailed resource for all this info and a full DIY here:
https://www.civicx.com/forum/thread...-bar-on-normal-civic-sedan-coupe-hatch.15191/
Mr.Apex
Dylan
Bay Area Ca.
2020 Si Sedan
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
I have installed in my car the RSB from the Type R also the end links of the accord, I can affirm that the upgrade is worth it since it greatly improves the maneuverability of the car in curves and the weight transfer in the back of the car, all of the above accompanied by the eibach pro kit springs.
