Here is a photo of the warranty work .So after some drive i hear the same noise when im off the brakes .I took mine in today and it was the rear brake caliper not fully releasing after braking . Had the caliper , pad , and the parking brake motor replaced under warranty . So jack the car up and put it in brake maintenance mode , spin all 4 wheels and check for drag .
That would make sense in this case because it's partially rubbing. I hope this doesn't become an issue for all our Type Rs and if it is, they better put out a bulletin to have it repaired. I wonder if taking it in and out of brake hold mode or even turn off and on the E-Brake will help remedy the problem.Here is a photo of the warranty work .
