Creaking Noise When Decelerating with Minimal Brake Pressure
kestrel
2018 Civic Hatchback Sport Touring SGP
I currently have ~42K KM on my 2018 Civic Hatch Sport Touring and I recently noticed that when decelerating with very light brake pressure (e.g.: approaching a stop sign from a distance), there is a creaking sound coming from the front of the car. In addition, the same creaking sound occurs when turning the steering wheel lock-to-lock.
I've double checked the torque on my upper strut mount and my wheels so far, but the sound still persists. Has anyone experienced/solved this problem?
Video of Creaking Noise
kestrel
kestrel
Anyone?
Ricardowelch
Ricardo
1511 Willow Greene Drive
2016 Honda Civic
I currently have ~42K KM on my 2018 Civic Hatch Sport Touring and I recently noticed that when decelerating with very light brake pressure (e.g.: approaching a stop sign from a distance), there is a creaking sound coming from the front of the car. If you want to buy best pex crimping tool, just visit AutoGuysLand to review their post about this item. In addition, the same creaking sound occurs when turning the steering wheel lock-to-lock.
Try to check your power steering fluid. It could be low and cause this issue.
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
:confused1: :lol: dude civic is electric power steering. I don't know where you have seen power steering fluid reservoir
saiko21
Sai
Sacramento
Check your swaybar linkages and ball joints just to be safe. Also, Axles might be a culprit.
The dumbest problem would be the brake metallic spring might need some adjustment which may be scraping or shaking in the brake caliper assembly which is easiest and cheapest fix
kestrel
kestrel
In case anyone has the same issue - the culprit was the brake pads burning in on the rotor.
Honda Civic 10th gen Creaking Noise When Decelerating with Minimal Brake Pressure 5lB3BRb
Honda Civic 10th gen Creaking Noise When Decelerating with Minimal Brake Pressure C5R2Me
The problem has been solved with a new set of pads/rotors.
Honda Civic 10th gen Creaking Noise When Decelerating with Minimal Brake Pressure BMLwDuY
@that_1redcivic
Milly
Pittsburgh, PA
2020 Honda Civic Hatchback Sport (CVT)
Having the same exact issue, did everything correctly installing new pads and rotors and getting this sound again. Any ideas? Front sway bar bushings? It sounds like this but worse than what OP was having.
