Considering a HKS bov
Sayanythng
Trevan
Grants pass
Fk8 2020
Talk me out of it? I see there isn’t much data showing it’s harmful. Can someone link me?
Naimahab
South Florida
2017 Honda Civic Si Coupe
Agreed. I want some actual facts here, tired of the "it might have bad effects" like we been in 10th gen for how long? No one got an answer?
ayau
Subaru
Makes the car run poorly. Air fuel numbers will be thrown off. If you're fine with that, then go for it.
Naimahab
South Florida
Run poorly how? The numbers can't be fixed with a tune?
ayau
Subaru
Naimahab
South Florida
ayau
Subaru
I don’t see a data log showing anything Im missing something in that link?
There wasn't a data log in that link but I recall seeing one before. Just have to search around.
You'll see the AF numbers go crazy whenever you lift/the BOV releases the air. The extra air is supposed to stay inside the system and recirculate back into the intake manifold, but the BOV releases it, so that will just throw everything off.
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
We very recently went over this in another thread.
Here's my post on it: https://www.civicx.com/forum/threads/oh-no-not-another-bov-thread.57978/post-926483
And here's Derek Robinson's post on it, although it's more specific to the base/Si: https://www.civicx.com/forum/threads/oh-no-not-another-bov-thread.57978/post-925322
tl;dr: The Type R ECU has a very precise and sensitive airflow model that depends on the air being kept inside the charge pipes, otherwise the entire ECU's calculations will be off. It's more than just having incorrect AF ratios, nearly every table in the ECU is based on this calculation. It's a bad idea on an Si, but an even worse idea on an R. That being said, if you're willing to sacrifice the Bosch ECU's strategies designed to keep the engine safe in exchange for some sounds, by all means go for it. It does sound pretty cool.
