1.5T CompTurbo Billet Wheel Upgrade
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
Hope the 11 blade exhaust turbine wheel performs better than it did with the 9 blade Si turbine wheel:hmm:
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
2017 Civic Si, 2019 Accord Sport 2.0T, 2001 Integra Type R, 2019 RDX A-Spec
The base model exhaust wheel probably spools faster than the 9-blade Si, but total flow will be down.
FK7Hatch
MD
17' Civic Hatchback Sport
Installed the turbo on Monday... Took about 4 hours to do and was kinda a pain in the ass. I'm running it on the stock map while waiting for my ktuner to show up from Derek. I'm going to probably get it etuned by Steve in the mean time until I get a clutch to do a proper Dyno tune with Derek. My impressions on the stock map so far, is that the torque hit is gone, instead it starts to spool around 2.5k and you get smooth power from there all the way to redline.
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Your not suppose to push it to redline on stock map for upgraded turbo
FK7Hatch
MD
Don't see why not, boost targets are managed by the electronic wastegate, it should just run whatever boost and timing that is targeted in the stock map.
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Not what I meant lol on stock map you shouldn't be running to redline on the Comp Turbo unless you are getting it datalogged for a tune. That's why most people don't push their upgraded turbo's unless they are tuned for it. AFR's aren't tuned and can be harmful on stock map.
FK7Hatch
MD
point taken, luckily I only did that run once, taking it easy until I get it tuned
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Yes that would be best since you don't want your rods bending lol
FK7Hatch
MD
On Rev1 tune with Steve at etunez.. looking at the logs, WOT starts spooling around 2.5k about 10psi at 3k. peak boost of 21psi at around 4k, all the way to 6.5k rpm
Two Step Performance
twostepperformance.com
Getting it on the Dyno?
I believe I read the tune with Steve was just something temporary until he takes it in for a dyno tune.
