code A14 , 2018 ex civic, $1800?
civic2018ex
Rem
Tacoma
civic 2018 ex
Got code A14 im at 98,000 miles,Honda dealership did oil change,spark plug $400. Gave me a quote for 1400 for Drive Belt, Waterpump,coolant change, break fluid flush. Is it a fair price? And mechanic said serpentine belt. Is the Drive belt, serpentine belt, timing belt all the same ? I have no idea about cars.
SethNES
Seth
Austin area
2019 Honda Civic Si Coupe
Just googling A14 code shows (The A - Oil Change, 1 - Tire rotation and 4 - change spark plugs)
Water pump seems like bs to me. I doubt you are having overheating issues.
Not sure about belts. Tried to see in manual if it has when to replace due to mileage but couldn't find. I'll keep looking and edit post if find.
Seems like they are taking advantage of you possibly spotting that your knowledge isn't great on cars.
Brake fluid is probably legit considering Honda wants it every 3 years. However it should have maintenance code 7 when it needs replaced. I just turned mine off and will replace within 4 years since I'm only at 16k miles.
calonzo
New Haven, CT
2016 Honda Civic Touring
Civic X cars don't have a timing belt. They have a timing chain, which last a long time. Unless you are having issues there is no need for this service.
SethNES
Seth
Austin area
Only thing I could find was dealership pamphlet for all models that says to inspect water pump. I highly doubt they even did that since takes some time to get in there. If you aren't having any cooling issues then you are fine no need to replace the pump and since there is chain and not belt you are fine on that also.
Honda Civic 10th gen code A14 , 2018 ex civic, $1800? IMG_20221108_083109633
Honda Civic 10th gen code A14 , 2018 ex civic, $1800? IMG_20221108_083156054
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
Oil change makes sense of course.
Plugs at 100k make sense.
Waterpump? ehhhhh only if its squealing! Never a bad idea to change coolant.
Brake fluid makse sense at that mileage if it's never been done.
Not sure what they mean by a drive belt? Timing chain is what these motors have and unless you have serious issues running, doubtful it is needed. I would ask what they mean.
These motors have 1 serpentine belt to run ancillary things like AC, water pump, alternator and thats about it. They are rather easy to change at a shop and are usually in the $70-$100 price range.
Labor is the killer on that job.
Take it as you will. If they quoted you $1,400 for all of that I would say it's slightly high but in the "stealership" range.
VTecYoSelfB4UWreckYoSelf
Kevin
2020 Civic Si Sedan Aegean Blue
Yes everything on that maintenance schedule looks good other than the fact there is no timing belt to inspect. Sounds like the dealer is trying to make some money off you
civic2018ex
Rem
Tacoma
civic 2018 ex
Thank you all for replies, the recommendation here on my invoice says water pump package,drive belt, auto tensioner ...what is auto tensioner?
latole
Vaudreuil,Quebec ,Canada
Google have the answer for any question ; Auto tensionner ;
It keep the belt tight
Honda Civic 10th gen code A14 , 2018 ex civic, $1800? Capture d’écran, le 2022-11-08 à 14.36.34
calonzo
New Haven, CT
It keeps the correct tension on the serpentine belt. No need to change that unless your belt is loose or making noise.
