zroger73
- Apr 15, 2017
- 56
- 2,477
- 4,544
- United States
- 2019 MX-5 Miata GT-S, 2021 Ridgeline RTL-E
All automatic transmissions have a neutral position. There is nothing in the Civic's manual that says you aren't supposed to coast in neutral.Well then that's the automatic tranny and not even relevant. You can't coast in neutral in an auto, I would never do that. This discussion is about the manual tranny...
However, coasting in neutral with an automatic transmission is a bad idea for at least two reasons:
1) If the engine is not running, there's no pump to circulate fluid through the transmission for cooling and lubrication. This isn't an issue for a manual transmission.
2) It's illegal in many states as previously mentioned.
Supporting point number 1, the manual states that the vehicle should be towed either on a flatbed trailer or with the front wheels off the ground.
The days of being able to do that are numbered thanks to the brake-throttle override on most new vehicles with electronic throttle control, including our Civics. Pressing the brake pedal while in motion releases the throttle.Better than a double foot habit. Seeing people driving around here with the brake pedal pressed all the time drives me insane.
