kseriesparts
- Nov 18, 2016
- 117
- 746
- 134
- Colorado
- 03 Integra Type-R, 02 RSX Type-S, 2016 Honda Accord v6, 2000 Integra GSR
FX100 - STREET
70% INCREASED HOLDING CAPACITY
https://www.kseriesparts.com/cr/CLM-08150-HD00-D.html
https://www.kseriesparts.com/cr/CLM-08150-HD00-R.html
The FX100 system uses a heavy-duty pressure plate with a custom heavy-duty steel sack srganic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation, *
All stages come as a complete kit including disc, pressure plate, throw out bearing, pilot bearing (when applicable) and alignment tool.
(Individual components available upon request)
*Organic/ Kevlar/ Formula Button Clutch kits are expected and tend to have a higher life expectancy than OEM, however not guaranteed. Improper Installation, Driving style, performance upgrades, Break in procedure and light-weight flywheels will affect and have a role in determining the life expectancy of the clutch kit.
FX200 - STREET
https://www.kseriesparts.com/cr/CLM-08150-HDKV-D.html
https://www.kseriesparts.com/cr/CLM-08150-HDKV-R.html
The FX200 System uses a heavy-duty Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque rating and holding capacity as the FX100, however, its life expectancy is increased with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer. Minimum 500 required break-in miles. Please see the technical guide for more details. *
All stages come as a complete kit including disc, pressure plate, throw-out bearing, pilot bearing (when applicable), and alignment tool.
*Organic/ Kevlar/ Formula Button Clutch kits are expected and tend to have a higher life expectancy than OEM, however not guaranteed. Improper Installation, Driving style, performance upgrades, Break in procedure and light weight flywheels will effect and have a role in determining the life expectancy of the clutch kit.
FX250 - STREET
110% INCREASED HOLDING CAPACITY
https://www.kseriesparts.com/cr/CLM-08150-HD0F-D.html
https://www.kseriesparts.com/cr/CLM-08150-HD0F-R.html
The FX250 System uses the Power Plus I Pressure Plate and a hybrid combination of Clutch Masters New Formula Button on one side and a heavy-duty Steel Back Organic friction lining on the other. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX250 clutch system has a higher holding capacity than a traditional full faced Kevlar without compromising the street friendly characteristics Clutch Masters is known for.
* All stages come as a complete kit including disc, pressure plate,throwout bearing, pilot bearing (when applicable), and alignment tool.
FX300 - STREET
https://www.kseriesparts.com/cr/CLM-08150-HDTZ-D.html
https://www.kseriesparts.com/cr/CLM-08150-HDTZ-R.html
The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement. The FX300 is only recommended for the street and not for the track. Minimum 500 Required break-in miles. Please see The Technical guide for more details.
All stages come as a complete kit including disc, pressure plate, throwout bearing, pilot bearing (when applicable), and alignment tool.
FX350 - STREET/RACE
https://www.kseriesparts.com/cr/CLM-08150-HDFF-D.html
https://www.kseriesparts.com/cr/CLM-08150-HDFF-R.html
The FX350 System uses the Power Plus I Pressure Plate with Clutch Masters New Formula Button disc. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX350 clutch system has a higher holding capacity than a segmented Kevlar lining without compromising the street friendly characteristic Clutch Masters is known for. For year’s enthusiast have had to compromise durability for drivability and vise versa, however with Clutch Masters New Formula button we have closed the gap between these two tradeoffs. *
FX400 - RACE/STREET
170% INCREASED HOLDING CAPACITY
https://www.kseriesparts.com/cr/CLM-08150-HDB6-R.html
https://www.kseriesparts.com/cr/CLM-08150-HDBL-R.html
https://www.kseriesparts.com/cr/CLM-08150-HDC6-D.html
https://www.kseriesparts.com/cr/CLM-08150-HDCL-D.html
###-##-HDCL Eight Puck Disc (shown on the left)
###-##-HDC6 Six Puck Disc (shown on the right)
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4,6 or 8 wing (paddle) configuration, with the 4-wing being the more aggressive setup and 8-wing being the less aggressive (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more street friendly than solid or rigid designs. This disc is designed for outstanding holding capacity, and rapid heat dissipation. The FX400 ceramic paddle design creates a quick and rapid engagement as well as clutch chatter that may not be ideal for street driven vehicles. *
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
*Ceramic based clutch disc are not intended to increase the life expectancy of a clutch rather to increase the holding capacity and improve the durability of the clutch. Using a ceramic based material for easy street driving may reduce the life of the clutch kit due to harsh engagement and higher tendency to slip the clutch kit. Ceramic disc are never recommended for stock or near stock vehicle applications.
FX200 - STREET
FX250 - STREET
FX300 - STREET
FX350 - STREET/RACE
FX400 - RACE/STREET
