David228cx
- David
- Apr 24, 2019
- 10
- 230
- 144
- Spain
- 2017 Red Honda Civic Sport (EU)
Is this retrofit setup dualmass flywheel from the CTR?
CTR Oem flywheel is singlemassIs this retrofit setup dualmass flywheel from the CTR?
This car does not use a pilot bearing, the bushing also does nothing anyway, we don’t even use them in our k series buildsHaha I was trying to see what the pilot bearing situation was
Thanks for pics!
No it will not. Eman said that you don't need a pilot bearing and he never ever runs one.No pilot bearing...is this going to impact longevity/reliability?
You don't need a pilot bushing.Next question - how do you align the clutch when installing it when there is no pilot bushing the stick the alignment tool?
The factory flywheel does not use a bearing, a bushing is used and it does not do anything with regards to support, operation use or longevity, from experience these things usually over time fall off or heat up and seize on the input shaft and cause a ton of problems ask (spec). Also it’s the same bushing used in the older k series world which in all my experience from that platform dating back to 2007 has always been a issue as I described above.No pilot bearing...is this going to impact longevity/reliability?
Here’s mine after 11,000 miles or so. Fx350 was still fine but the pilot bushing just got destroyed and fell out.The factory flywheel does not use a bearing, a bushing is used and it does not do anything with regards to support, operation use or longevity, from experience these things usually over time fall off or heat up and seize on the input shaft and cause a ton of problems ask (spec). Also it’s the same bushing used in the older k series world which in all my experience from that platform dating back to 2007 has always been a issue as I described above.
Exedy stage 2 and exedy smf. Different from type r retroDid you ever finish the job? I was wondering about your results? I think it was intelligible of you to fix a pilot bushing to the SMF instead of “just sending it like most. Any Updates???
How is it going?Exedy stage 2 and exedy smf. Different from type r retro
