Civic Type R After-market Wheel Guide
Green82
Oklahoma
2019 Type R
you guys think a 20x10 +45 offset would fit my 2019 type R without problems?
can also get the same wheels in 20x8.5 +35 offset but heard that might rub and cause crazy torque steer
what about tire stretch? its something i dont like the look of so might have to do a wider tire.
im not real familer with what all the offset does to the look of the wheels
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
Superspeed RF03RR 18x9.5 in bronze on a white Type R since I couldn't find any pictures before buying (including Google search) figured I'd share here. Would have better pictures but its been cold since install.
Honda Civic 10th gen Civic Type R After-market Wheel Guide 20210107_162618
JohnEBlaze
fTX
‘18 CW Type R
Looks great. How much do the wheels cost?
Boofneenee
Massachusetts
Civic type R
Hi
Their is an amazing set of Te37 saga bronze rims for sale near me with tires! I'm nervous about the fitment on my car because I will not be adjusting ever the suspension or ride height.
The wheel size is 18 9.5 22 offset
He used it on ctr with coilovers and camber kit. He said his was slightly lowered and did not rub. He said he is "pretty sure" it won't rub in stock ride height.
Looking for help
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
Hi
Looking for help
I'm on 18s 9.5 +38 at stock height with 255 width tires and their is an inch and a half clearance. You'd have to run 255 or less to avoid rubbing from what I'm figuring. See if anyone else chimes in tho.
spyder57
LA
ABP CTR
Hi
Looking for help
Lol he's 100% full of it. +22 is super aggressive and you're guaranteed to rub. That's a fitment meant for bmws not our cars.
Boofneenee
Massachusetts
Civic type R
Would an offset with a lower positive number be more aggressive than a higher positive offset number?
The rim I'm looking at is 22 vs someone with same dimensions and a 48 offset.
Thanks
spyder57
LA
ABP CTR
Thanks
The lower the offset, the more aggressive the stance i.e. the more the wheels will poke out from the fenders. Stock offset is +60, reducing that too much will cause rubbing and torque steer.
RepyT
Almost Stock ‘19 R on 255/35-19”
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Hi
Looking for help
What is tire width? You didn’t say. With 9.5” wheels you have an inch either way.
Like others said, good chance will rub.
Don’t guess, compare OEM (245/30-20 on 8.5”w at +60 (aka ET 60) to your tire and wheel size using this calculator.
Pay attention to overal diameter that impacts Speedo accuracy, but more important, what it does to scrub radius, clearance and then you’ll likely pass, big spacers needed, not to mention camber changes w/without spacer.
Welcome to resale city if you buy.
Wheel & Tire Size Calculator
m_kluch
Maryan
Michigan
2018 Civic Type-R
20x10 +45 will most likely rub especially if you dont like stretched tires and get at least a 265mm wide tire. The 20x8.5 +35 is the less aggressive of the two choices and will clear with no rub.
