Eddie_69
- Eddie
- May 31, 2019
- 0
- Los Angeles
- 2019 civic si
Hello looking for some advice I got a 2019 civic si sedan I’m having problems with I replaced my bypass valve with a blow off valve installed it properly however I forgot to connect the turbocharger position sensor back on turned the car on and I got a check engine light on I knew right away it was because I forgot to cone the sensor I turned the car off and connected the sensor back on however check engine light remained on I drove it around seeing if the ecu would recet but no luck I disconnected the negative terminal on the battery and connected it back on the check engine went off but now it showed my system was initiating the check engine came back on I tuned the car off for 10 min and took off the ecu fuse to rest the ecu now the light has gone off and all the warning lights to and didn’t come back on however I was experiencing turbo lag with this mole bov on the car was sounding a lot cooler however wasn’t performing the way it was suppose to I read some reviews that perhaps I should’ve done before buying the bov and some people have experience same lag so I decided to take it off and put the stock bypass valve back on hoping to regain my loss of power this time I connected the turbocharger sensor back on before turning the car on but the check engine came back on even with the stock part and would go into sport mode I decided to do the same procedure I had done previously everything went off again and has not come back on however I’m still getting they turbo lag I conected my obd 2 scanner and it’s reading the turbocharger position sensor even though it’s conected and also my im monitors such as as catalytic converter and other monitors are not showing ready what should I do? Perhaps the turbo lag wasn’t coming from the blow off valve but form another malfunction because it’s doign it still with the stock part any ideas ????
