rhino
- jacob
- Jul 15, 2019
- 5
- 5,329
- 6,643
- Weeb land!
- 2015 sr5 access cab, 98 civic hx ej7, 2003 KLX400s
- Vehicle Showcase
- 1
how do they ride?Hooked up a friend with the Whiteline Springs, and I'll have them on my Si next month as well. Reverting back to stock dampers from current K-tuned Coilovers setup as I want a more compliant ride
0.8" / 20mmdrop, installed in less than an hour by my tech who's done all the work on my car. Was happy to see that alignment was dialed back to spec without requiring a Camber Kit, and that the bump stops didn't need to be trimmed as they did with my H&R Springs when I was running those two years ago.
NOTE: the Whiteline stamp on the springs is not directional, this has confused some forum members as I've seen in the past especially when it comes to the Rear Springs. When you look at the rubber bushings below, it's very easy to see which side the top and bottom bushings go on as the larger end on the coil will accommodate the larger bushing, and smaller end accommodates the smaller bushing.
