Mr.Apex
- Dylan
- Jan 3, 2020
- 2
- 73
- 78
- Bay Area Ca.
- 2020 Si Sedan
I am new to this platform and forum and had run into troubles trying to find lowering spring info and options for the 10th gen SI (FC1/FC3) so i decided to create a master thread dedicated to the SI specifically like the one that exists here for the Type R (FK8).
Another good reference thread is here where members have posted pictures of most setups.
All info is from a representative at the company or the companies website itself.
If you found this thread helpful please shoot me a thanks id really appreciate it.
SI OEM
Front Spring Rate: 144.186 lbs/in
Rear Spring Rate: 208.776 lbs/in
(FK8) CTR OEM for reference
Spring Rate Front: -263.2 lbs/in
Spring Rate Rear: -235.2 lbs/in
Eibcah PRO-KIT Performance Springs
2017- 2020 Civic Si Sedan/Coupe
Part # E10-40-036-02-22
Drop Front: .9"
Drop Rear: 1.1"
Spring Rates (Progressive)
Front: 137-177 lb/in
Rear: 83-256 lb/in
$230
Best price found here
Eibach SPORT LINE
2017-2020 Civc Si Sedan/Coupe
Part # E20-40-036-02-22
Drop Front: 1.7"
Drop Rear: 1.8"
Front: 120-202 lb/in
Rear: 74-280 lb/in
$261 Everywhere
D2 Racing Lowering Springs
2016-2020 Honda Civic/2017-2020 Civic Si
Part# D2R D-SP-HN-25-3
Front Drop (Coupe/Sedan): 1.7"
Rear Drop (Coupe/Sedan): 1.9"
Progressive Spring Rate
Spring Rates 20% Stiffer than stock
Approx Math Front 173.02 lb/in Rear 250.54 lb/in
$170
Swift Spec R
17+ Civic Sport/SI
Part# 4H918R
Front Drop: 1.1"
Rear Drop: 1.1"
Spring Rate (Dual)
Front 229.5 lbs/in
Rear 319.2 lbs/in
$298
Skunk 2
'16-'18 Civic
Part# 519-05-1775
Front Drop: 1.375"
Rear Drop: 1.25"
Progressive Rates
Drop varies by chasis not specifically listed as SI compatible
$173
K Tuned
16+ Civic (Coupe/Sedan/Hatchback) - DOES NOT FIT TYPE R
Part# KTD-K1S-FC3
Drop Front: 0.9"
Drop Rear: 1"
Spring Rate (Front): 173.6 lb/in
Spring Rate (Rear): 252 lb/in
$270
Whiteline
Listed as compatible with all 10th gen
Part# WSK-HON017
Drop Front: .8"
Drop Rear: .8"
Spring Rate (Progressive)
Front 253 lb/in
Rear 286 lb/in
$233
Tein S Tech
FC1/FC3/FK7
Part# SKHH6-AUB00
Front Drop 1.2"
Rear Drop 1.0"
Spring Rate Front 146 lb/in
Spring Rate Rear 174 lb/in
$172
Tein H Tech
SI 2DR/4DR
Part# SKHH6-BUB00
Front Drop .06"
Rear Drop 2DR .06/ 4DR .04
Spring Rate Front 134 lb/in
Spring Rate Rear 162 lb/in
RS*R
2016+ Honda Civic Coupe / Sedan
Part#: H057D
Drop for Coupe:
Front 1.0in to -1.2in
Rear 1.4in to -1.6in
Drop for Sedan:
Rear 1.2in to -1.4in
Spring Rates
Front 148.40 lb/in
Rear 188.71 lb/in
$245
H&R Sport Springs
2016-2020 Honda Civic (Community confirmed fitment with SI)
Part# H&R 51892
Front Drop ~1.25"
Rear Drop ~1"
$233
Fell free to post pictures of your setups just be sure to list what springs youre running.
If any of this info is incorrect please let me know or if you have something to add and ill continue to update this post.
SI OEM
Drop Front: .9"
Drop Rear: 1.1"
Rear: 83-256 lb/in
$230
Eibach SPORT LINE
Drop Front: 1.7"
Drop Rear: 1.8"
Rear: 74-280 lb/in
$261 Everywhere
$170
Swift Spec R
17+ Civic Sport/SI
Part# 4H918R
Front Drop: 1.1"
Rear Drop: 1.1"
Spring Rate (Dual)
Front 229.5 lbs/in
Rear 319.2 lbs/in
$298
Skunk 2
'16-'18 Civic
Part# 519-05-1775
Front Drop: 1.375"
Rear Drop: 1.25"
Progressive Rates
$173
K Tuned
Part# KTD-K1S-FC3
Drop Front: 0.9"
Drop Rear: 1"
$270
Whiteline
Part# WSK-HON017
Drop Front: .8"
Drop Rear: .8"
Front 253 lb/in
Rear 286 lb/in
$233
Tein S Tech
FC1/FC3/FK7
Part# SKHH6-AUB00
Front Drop 1.2"
Rear Drop 1.0"
$172
Tein H Tech
SI 2DR/4DR
Part# SKHH6-BUB00
Front Drop .06"
RS*R
Part#: H057D
Drop for Coupe:
Drop for Sedan:
Spring Rates
Front 148.40 lb/in
Rear 188.71 lb/in
$245
H&R Sport Springs
Part# H&R 51892
Front Drop ~1.25"
Rear Drop ~1"
$233
