yes, there is factory 6pin connector for all interior illumination accesories.So, the civic door sills are just plug and play? There are already existing plug in ports under the dash?
That's really good to know! Does the passenger side have a long enough wire to reach? I'm guessing yes. How do you run it so it's hidden? Behind all the panels under the dash? I didn't see how you tucked all the wiring in the video. Maybe I missed it. Is it just one 6 pin connector or are several for multiple lighting accessories? Sorry for all the questions, I just want to be sure. Thanks.yes, there is factory 6pin connector for all interior illumination accesories.
Ah yes. I found a diagram just now too showing that. Looks like a simple install. I had a door sill illumination kit for my Honda CR-Z too. It came like that as a dealer installed option. Look great. I may pick this up in the future. Thanks for the help! I like how this one is RED. Matches the Si's red theme.yes i run it under dashboard panels (over passanger lower dashboard panel, than behind
center console and than again over driver's dashboard lower panel and like you can see on the video on the left corner there is that 6pin connector (that is used by all interior illumination accesories) . and the wiring is very long so no worry about it.
This is soooo awesome. Can you share the broad steps and tools you needed to make it work?the difficult part was to change F to C degrees. it require to decode and flash eprom of AC module and gauge cluster memory.
