Civic of Brazil
So in the United States, do you use the MILITEC metal conditioner?
  • Yes
    Votes: 4 36.4%
  • No
    Votes: 7 63.6%
  • I USE OTHERS
    Votes: 0 0.0%
  • Total voters
Gabriel Reis
Gabriel
Brasil, Paraná
Civic Sport 2017/2017 MT6
The following text was translated by google translator
Good morning guys, how are you?
Decided to present my civic, here in Brazil, as far as I know, it has some differences from the United States civic
His engine is a R20Z1(SOHC), this engine has 155 hp, using ethanol / alcohol as fuel
This engine can also use as gasoline fuel
(gasoline from Brazil is of very poor quality
We even have a joke, making a pun, calling it "gasolixo" (junk gasoline)
or also "Dinosaur juice)
In Brazil the Civic is considered a luxury car, it is a very expensive car, it has a very high value
Earning a minimum wage, it is necessary to work for more than 10 years, to buy a new turing
Here the oil change is done with 5,000 kilometers
under severe conditions of use, and 10,000 kilometers under normal conditions of use.
We use 0w20 oil, and unfortunately we do not have any high quality oil with these specifications
The original Honda oil, costs more than 50 Reais
What in direct conversion are 12 dollars, but doing the correct conversion, the original honda oil, in brazil it costs the equivalent of 55 dollars
My civic I bought it used, already with 2 years of use, and with 40.00
kilometers
It cost 76,000 Reais, direct conversion is equivalent to 18,200 dollars
What converting correctly, is equivalent to $ 85,000
Yes, in Brazil, a used civic sport costs the equivalent of $ 85,000
If you have any doubts, any questions, you can ask whatever you want
Honda Civic 10th gen Civic of Brazil WhatsApp Image 2020-01-17 at 9.05.22 PM (1)
Honda Civic 10th gen Civic of Brazil WhatsApp Image 2020-01-17 at 9.05.47 PM
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
Edit: He's using Continental tires, ExtremeContact 215/50/17
is one of the best tires that we have available to this extent in the Brazilian market
integraboi
Noah
Houston
2019 Civic Sport, Mk4 Jetta VR6
Wow, I've never heard of such an engine. In the states our Civics use K or L series engines.
I'm interested. Would you mind showing the engine or maybe some things that your Civic has that ours doesn't or vice versa?
ulieq
iowa
Sport Coupe 2019
Some south american countries have extremely bizarre and restrictive tarrifs. That doesn't mean civic is a luxury car in Brazil, only that it's tarriffed to the point where you're not supposed to buy it.
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
I live in brazil, i'm brazilian, and i say, in brazil, the civic is a luxury car
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
This is the Sport version, it is the most basic version
However, the most complete and most expensive ones have differences that are just technological, more comfort items, nothing special
Except for the turing version, which uses 1.5 turbo engine and has a more modern suspension, focusing more on comfort
this 1.5 turbo engine, is the L15B7, and has 173hp and 22.4 of torque
The civic SI is also an L15B7, however with 208 hp 26.5 torque / kgfm
Civic Si in Brazil is more expensive than Turing (Civic Si comes through imports)
Civic Si, and Civic Turing, are NOT flex, Honda's 1.5 turbo engines only use gasoline
In Brazil there is no Civic Type R, to buy it you must import it yourself, and this has an exorbitant cost
I believe that in Brazil, the R20Z1 engine is used, as it is cheaper and, perhaps, a matter of fuel consumption and quality
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
If you can tell me about the US civic, I would be very happy
What media does it do?
(the Brazilian Civic, depends on the fuel and driving mode, when alcohol / ethanol is used as fuel, it has more power, but it spends more fuel
Using in a normal way, and mixed use (city and highway) using gasoline as fuel, I make an average of 10 kilometers using a liter of fuel)
But if I try to drive in an economical way, it is possible to make an average of 18 kilometers per liter
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
The photos were taken at night, and my garage is not well lit, so the photos were of poor quality
The engine is a little dirty, because I live in the countryside, we have dirt roads, so it ends up getting very dirty
Honda Civic 10th gen Civic of Brazil 5a83e245-c272-48d2-8065-e671f1df7ecf
Honda Civic 10th gen Civic of Brazil 5d5c3716-6fb5-4778-a07a-d23cc8c85037
Honda Civic 10th gen Civic of Brazil 7dd754a1-c639-4d77-b121-2313e843cef4
Honda Civic 10th gen Civic of Brazil 7ece6f81-a8fe-4dd8-8fa6-4ee5c78c73f8
Honda Civic 10th gen Civic of Brazil 17d77ff2-ff22-4c1d-824f-91d1a5fc8ec2
Honda Civic 10th gen Civic of Brazil 730ee074-b401-494b-bbc8-40c13d8ba076
Honda Civic 10th gen Civic of Brazil 913c7227-d8d7-4b81-98e9-0a59ffe93646
Honda Civic 10th gen Civic of Brazil 71389b26-4244-4229-b895-7d0b15d2a1e8
Honda Civic 10th gen Civic of Brazil a0935f07-44e1-42a0-9ec5-0383c81ab0fa
Honda Civic 10th gen Civic of Brazil cb6dddc5-eaec-4c15-9e45-11eb7ee280a6
Honda Civic 10th gen Civic of Brazil e4e5c9c4-a47d-4593-a02b-3a5076b73da8
Honda Civic 10th gen Civic of Brazil f4a6241b-63f9-44f3-b847-38e798d62f36
Gabriel Reis
Gabriel Reis
Gabriel
Brasil, Paraná
Another question I have
What suspension do you have in your civic?
(In Brazilian it is multilink behind, and macpherson in front)
What fuel do you use?
(Brazil, cars in general, can use Gasoline or alcohol
In Brazil, by law, gasoline is required to have 25% mixed alcohol (this law is very bad)
Some gas stations, in order to be more profitable, add even more alcohol, along with gasoline (gasoline is more expensive than alcohol, gasoline has a higher value than alcohol)
Such practice is a crime
Many stations using other components mixed in gasoline and alcohol, to have a higher profitability, and this usually destroys the engine
There are also many fuel pumps that are rigged to mark a larger amount of fuel than actually entered the car’s tank.
In Brazil, it is not you who refuel your car, gas stations have an employee to fill your car, they are called "FRENTISTAS"
Due to fuels, and especially gasoline, it has a very high cost, it is common to install a "GNV" kit, making the car be moved to a type of GAS
I will leave the link to the honda do brasil website, so you can take a look at the available models
https://www.honda.com.br/automoveis/
I'll also leave a link to a website, where you can see the technical specifications of the civic, and practically all cars we have in Brazil
The link below has my specific civic information
https://www.carrosnaweb.com.br/fichadetalhe.asp?codigo=6241
Each version, year and model, has some differences
And the link below you can place up to 4 cars and make a comparison
https://www.carrosnaweb.com.br/compara.asp
(and finally, Honda and Toyota are considered to be one of the best brands, as they are hardly defective, and the repair costs are not usually so high)
CNG is cheaper than gasoline, the cost per kilometer is less
However, the engine suffers greater wear
If you can tell me exactly what your civic engine is, what its power is, what fuel it uses, and the oil change period, I would be grateful
integraboi
Noah
Houston
Very cool! Seems like we have pretty much the same car.
The most noticeable difference would be the engine, mine comes with a K20c2. The K20c2 runs off of regular pump gas in America which would contain up to 10% ethanol.
Other than that, I don't see anything else that would be different than the ones we have over here. But maybe some of the other guys on the forum can spot some things.
Gien97
Elmer
Philippines
Civic 1.8L E 2020 R18Z1 (FC6) Southeast Asian
I have a Civic FC6 R18Z1 CVT.
Can you tell everything needed to convert it to Manual?
