1.5T Cherry bomb ,low cost better sound
Hrubovcak.jh
Jozef
Slovakia
Honda civic 1.5 T sport hatch
Hi, has anyone replaced replaced resonator with cherry bomb only and left mufflers in place? If not, do you think it would be beneficial? If yes, do you by chance have a video with a sound of it? Thanks for your replies
dellyjoughnut
Los Angeles, CA
Toyota 4Runner, '19 Civic Sport Hatchback
The cherry bomb will not cancel out the droning resonant frequencies due to design. It will act as a muffler.
Better sound? I've pretty much come to terms with the fact Honda L15 series engines will never have roughness like a V8 or the pops and crackle of a turbo Hyundai Elantra even with a catalytic converter. It's a buzzy bassy sound with less bright tones.
jtrader
James
OH
2018 Civic Hatch Sport, 2009 Odyssey
If by cherry bomb, you are talking about a glasspack muffler, then yes I did the opposite of what you describe. Replacing the resonator with a cherry bomb and keeping the muffler would have very little effect on sound. If it's increased sound you want, you would be highly disappointed. But you're on to something....
I kept my resonator and did a muffler delete. The drone was obnoxious. So I inserted a "cherry bomb" where my mufflers once were, and the sound is perfect. It's similar to a muffler delete but the glasspack does an excellent job of removing drone.
Under my sport hatch.... DIY style.
  • Like
Reactions: Myx
Hrubovcak.jh
Hrubovcak.jh
Jozef
Slovakia
  • #5
thanks for the info and photo. and what about high speed? isn't it too loud like that? do you have a video what sound does it make me?
jtrader
James
OH
Here you go sir. It's definitely not too loud. I would say the sound level is perfect. At cruising highway speeds, you don't hear it. You really only hear it when you're *getting on it!*
And this was before I added the glasspack. Straight muffler delete.
  • Like
Reactions: Myx
Hrubovcak.jh
Hrubovcak.jh
Jozef
Slovakia
  • #7
Many thanks for the video. I'll do it then. Did you make new pipes or did you just adjust the OEM pipes?
jtrader
James
OH
I can't make pipes, I'm just an average Joe schmoe with a hacksaw and socket wrenches. I bought 2" pipes from autozone and o'reillys and I pieced them together with clamps. I cut the OEM on the straight section of pipe right before it makes the first 45deg bend toward the muffler and pieced it back from there.
Hrubovcak.jh
Hrubovcak.jh
Jozef
Slovakia
  • #9
I can't make pipes, I'm just an average Joe schmoe with a hacksaw and socket wrenches. I bought 2" pipes from autozone and o'reillys and I pieced them together with clamps. I cut the OEM on the 45° bend in front of the mufflers and pieced it back from there.
Okay , thank you!
Hrubovcak.jh
Hrubovcak.jh
Jozef
Slovakia
  • #10
How did you grip the "new pipes"? I saw a bit in the video, but could you please take a detailed picture of it?
jtrader
James
OH
Ok, try this..... I've also included a link to a splitter/tip combo below, which I did not use...but I probably should have!!!! It would have been better/easier.
Rather than buying a y-splitter and 2 tips.....you can simply buy this splitter/tip combo, which would connect nicely to the 2" pipe exiting the glasspack. The exhaust hanger will attach easily on that pipe as well.
https://shop.advanceautoparts.com/p...-ex-2012/10027721-p?c3ch=PLA&c3nid=10027721-P
  • Like
Reactions: Myx
Hrubovcak.jh
Hrubovcak.jh
Jozef
Slovakia
  • #13
Hi.
Everything's finished. The sound has really changed. The sound from the outside is exactly what I wanted. There is a problem inside though. I think it gets too rumbly around 1900-2000rpm. Perhaps another cherry bomb would fix that - not glasspack, perhaps cherry bomb turbo. Holders were made in a way so they would fit on OEM rubber holders. Anyways, thanks a lot for the videos and photos. It was still useful and I'm very satisfied.
Jjakef96
Jake
Cincinnati
2021 Civic Sport Hatchback
I used this to show an exhaust shop to do the same on my 2021 sport hatch and I notice very similar sound while the turbo does not have a load. It is a low deep rumble sound. However once the turbo is at half or more of its load, the rumble is almost gone. Instead I just get more of a low whistle like sound. Almost jet engine like. Wondering if anyone else that has done this is experiencing the same thing or not. I will try to get video soon.
jtrader
James
OH
Interesting. I never heard what you described, it sounded good throughout the entire range. However, I do have an update. I removed my cherry bomb and put the stock muffler back on! Then I removed the resonator with a straight pipe. After listening to all the exhaust vids, I decided to do a res delete. After living with it for a few weeks, I believe a resonator delete > muffler delete. Anyone else agree? I really like the new sound. It just has an angrier tone to it....
