Sunnohh
- Joseph
- Oct 13, 2020
- 13
- Midwest
- 2016 Civic base manual
Howdy,
My old man does my oil changes and with the whole covid crap going on I dropped the car off and he worked on it the next day. He jacked it into the air and turned the engine on to get some heat into the oil before doing the change. Car is 2016 four door base model, manual transmission.
He came back about 10 minutes later and since then I have had the following lights:
tcs off when starting
tcs orange
electric steering orange
tpms orange / flashing when started
brake light red
brake system orange
The parking brake makes a horrible noise when trying to engage when running since this started, it won't even try when the car is off.
Any help much appreciated. Is this normal if you run the car on jack stands? If so, is there an easy fix, I've put a cycle of driving on it and the lights are unchanged. We have not disconnected the battery yet. He did pull the main fuse, but assumed if I have to take it to the dealer they will want the codes. Other posters have mentioned something about an ecu fault that is common but, I also saw a few posters imply that you can't run the car while it's off the ground. Neither seemed to have much actual info....
Thanks, first and hopefully not last honda... this will be my 4th issue since buying it new. I came from a dodge neon and never had issues like this car. Actually just replaced a control arm at 120k and nothing else on that car, lol. So far I have been in for, horrible quacking noise from the gas lid, 2 unexplained check engine lights that required major repair they wouldn't actually tell me how they fixed it at the dealer, and now this.
tcs orange
brake light red
brake system orange
