LXCivicX
- John
- Oct 17, 2017
- 14
- 10
- San Diego, CA
- 2017 Civic LX Hatchback
Hi guys and gals,
New to the forum with my first Honda and my first post at civicx.
I got some good info from this site, so I thought I'd contribute back in however small of a way with a success story of an install that gave me better sound in an LX for very little money ($400 plus some supplies I already had like amp cables).
My goals were to improve the sound on the LX radio while retaining all stock functionality. I didn't want an aftermarket head unit, and I didn't want to give up any of the extremely practical interior.
Without knowing how it would all fit together, I went with the Alpine KTP-445U Power Pack for the main amp. At $150, this offers 45Wx4. I usually only upgrade the front channel speakers with any install and run the stock rears. This was no exception. I picked up a pair the Polk DB652. At $90, they should serve as a moderate upgrade from stock. For bass, I decided on the JBL BassPro SL. It is $250, but I was able to find a refurb for about $150. This brought the total to $400. You can see the relative size of everything here:
I admit I was guessing a bit on the fit of everything, and it ended up being a tight squeeze. Fortunately, everything went in exactly as I was hoping.
The Alpine is hidden out of sight - snuggled just behind and below the head unit. I put a very thin piece of foam insulation top and bottom of the amp, and was able to just jam it in there. It is very secure behind the A/C controls. The head unit barely was able to be jammed back into place directly on top of the amp. If you decide to go this route, make sure you have enough wire between the HU and amp as well as between the amp and factory wiring or it may be impossible to place the amp and plug in the HU at the same time. I am powering the Alpine through the head unit's 12V, 15 amp power wire. This is not normal for car audio amplifiers, but the instruction manual says it is OK, and after a couple weeks of testing, I have not had any problem.
The JBL fit exactly under the driver seat without taking any foot room from the rear seat. I did dremel away about 2" of the underseat plastic A/C vent to push the sub forward and make a little extra room for rear passenger toes. I have already had several people in the back seat without any comment on the sub. The sub sits far enough under the seat that the front part of the floor mat just covers about 1/2 of the sub and protects it from any mud or anything that someone might bring on board. It fits very securely like this with only zip ties attached to the front seat rails holding it in place. Overall the amp has a nice solid feel and I don't worry about it being damaged by a rear passenger with a restless leg. The way I positioned the sub was with the connections and knobs facing the front of the vehicle. This way, I can still make adjustments by reaching under the seat from the front driver footwell. It requires a little hand dexterity, but is definitely doable. The sub is powered by a 10 gauge amplified cable with a 20W fuse from the battery through the factory grommet for the hood release cable.
I initially provided signal to the sub from the factory HU's read channels and drove the stock rear speakers off the Alpine amp. Unfortunately this didn't work very well as I had to turn up the gain and bass boost on the sub all the way to get any real output. When I did that, the sub sounded like knuckles on wood. I believe this is a flaw with the JBL, as I also read another report of this problem in a review online. In order to solve this problem, I re-wired the amp so that the Alpine now provides a boosted single to the sub, and I switched the rear speakers back to the stock rear channels of the head unit. Obviously, I lost a little power to the rears, but I don't really care personally.
Anyway, now the system works perfectly and sounds pretty good. About on par with a good factory system, which is what I wanted. The mids and highs are clean and powerful. The sub provides a nice fullness. If I could wave a magic wand, it would be deeper and louder, but that's just not in the cards for such a small box jammed under the seat. Overall I would strongly recommend this type of an install. It took me the better part of a weekend to complete, but I find myself really enjoying music of all kinds now.
Shameless pic:
Shameless pic:
