They can be changed out, but you need to buy a adapter to use a aftermarket shift knobDoes anyone have any clue or ideas if the shiftknobs on automatics are replaceable or changeable? Thanks
So the shift knob went as expected..very easy.
Tools needed:
Phillips head
Thumbnails
Time 10-15 minutes
On the select lever there's a silver trim ring between the knob and the boot. On the ring are two raised indicators. If viewed from above they'd be in the 3 and 9 o'clock position.
Directly below these indicators hidden inside the boot are two tabs on the base of the knob. These basically hold the silver trim ring up.
Feel through the boot and locate the two tabs. Pinch both tabs with one hand while pressing down on the trim ring with your other hand. The trim ring will slide down. You can see in the first picture how the trim ring is separated. The bottom mounting screw is now exposed.
Next you're going to remove the black plastic cover plate from the front of the knob. It's held by two tabs located near the bottom of the cover. This picture shows the location of the tabs. This is where you'll want to place your thumbnails.
Insert a thumbnail on each side between the cover and the knob. Gently push forward towards the dash.The cover will pop off. The top mounting screw is now exposed. Here's a shot of the tabs inside the cover as well as the two mounting screw holes on the knob.
I used a stubby Phillips head to remove the two screws holding the knob on. Once the screws are removed the knob will simply slide up and off.
From this point everything is basically the reverse.
Add new knob and reinsert screws.
Pop plastic cover back on.
Slide silver trim ring up until it clicks in place.
I used this youtube guide:Apologies to revive this old thread but has anyone changed their knob? If you have, could you explain how and share some pics? Thanks!
The boot is held onto the clip by a zip tie. You MIGHT be able to clip it without removing whole assembly but spacing is minimal to work with. Love the pokeball Was going to do pokeball/dragonball it still might later on once I tire of the cf knob.So, this is what I ended up doing (I don't have pictures because I haven't received the items and my car, unfortunately, is at the shop due to being rear ended. However, once I receive the items, I'll be able to share a picture of the items and how it will hopefully be set up.
I bought the following:
Speed dawg adapter
https://www.speeddawg.com/universal-automatic-shifter-adapter-black/
Thread adaptor
https://www.speeddawg.com/metric-thread-shift-knob-adapter-kit-3-sizes/
10x1.50 Threaded Great Ball (Pokemon) knob (like the true 30 going on 9 child I am. Also, the link here is not the one I purchased since it's a 10x1.25...I'm just sharing it for reference!)
https://www.ebay.com/itm/POKEMON-RA...724810?hash=item238638cd0a:g:hWoAAOSwn-tZNvOo
The shifter adapter's threading is 16mm x 1.50 which is not the size I needed for the Great Ball. Luckily, speed dawg sells an adapter kit with multiple sizes which will fit the shifter adapter and allow me to change the size and (hopefully) use different threaded sized shift knobs. This is about a $50 investment, which isn't too bad.
My only issue with this set up is the boot. As seen in the video, the clips that hold the boot up are built into the OEM knob. By changing it to this set up, I will now need to find a way to modify the boot. A friend suggested removing the boot, but I'm not sure if that's something I want to do. In fact, if anyone has any hints, please, please, feel free to share! I am open to ideas!
Anyway, This is the solution I found to the original inquiry in this thread, I hope it helps other people too!
Where did you find this knob ?I used this youtube guide:
https://www.facebook.com/uniquecarbon891010/Where did you find this knob ?
