- Mar 21, 2018
- 43
- 1,778
- 2,433
- planet earth
- '13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
- Vehicle Showcase
- 2
- Banned
i've received many pm's so just going to post here to help...for those who asked, here is my go to arsenal for ceramic work i started doing for the last year or so out of 30 yrs of detailing. have tried several ceramic products and settled on what i personally like to use - gtechniq (made in uk). this is all done after proper surface prep work i do for each of my cars.
ceramic coating can be defined as: full (2 layer approach) or light (1 layer approach).
also, many questions have been asked - can you ceramic coat ppf/xpel? yes - absolutely BUT must be done properly else you kill the self healing property of xpel ultimate and now xpel ultimate plus (latest film, crazy good...what my whole ctr is covered with). this is the answer:
a) do NOT do full ceramic coating on ppf or let any shop do it. bad news for ppf as the coating will completely harden the pff which needs to be flexible and self heal.
b) DO use ceramic light aka exo v3 below on ppf/xpel and painted surfaces not covered with ppf (see below). this is what is called "hybrid protection" and is the best of both worlds. exo v3 is being used on my entire ctr's full xpel ppf as we speak since i don't have time to do it myself so shop is doing it for me.
proper surface prep is: 1) wash accordingly and clay while suds are on car, 2) 1 or 2 or 3 step polishing (menzerna polishes are my go to) depending on amount of paint correction i need to do, and 3) remove polish oils before the real stuff goes on. for gtechniq i use these in order of steps
1) gt's panel wipe - to remove all polishing oils: https://www.detailedimage.com/GTechni…/PW-Panel-Wipe-P871/…/
2) gt's c1 crystal lacquer - base nano/ceramic coat on painted surfaces (not ppf'ed). it's newer than the legendary crystal serum and easier to work with: https://www.detailedimage.com/…/C1-Crystal-Lacque…/50-ml-S2/
3) gt's exo v3 - this goes on standalone or on top of c1 crystal laquer for even greater effect of gloss, depth, and hydrophobic. this is my #1 product now. this also goes on top of ALL ppf/xpel covered areas not just the painted areas that have been done with step 2 above.
4) gt's c2 v3 liquid crystal - this is for between washes or after washes and topping off or rejuvenating the exo v3. this is by far the best light ceramic spray or quick detailer i've used.
btw gt’s crystal serum pro is only available for certified installers. they came out with crystal serum light (csl) for prosumer line. i like c1 crystal lacquer more cuz it doesn’t flash as quickly as crystal serum and if it does cure it’s easier to polish off. cs pro or cs light is almost impossible to get off if cured and has to be wet sanded off, not just polished off...ugh! this also ties back to why you should not and cannot do full ceramic on ppf - imagine the base/main level of ceramic curing on that expensive ppf you've just had installed...consider replacing that entire film section. therefore, ceramic light works wonders on ppf.
i buy all my detailing products at detailed image, which is cheaper than on amazon, but i also have a wholesale account for personal use because i spend over $1000 per year with them for my products. enjoy and happy detailing!
ps - you may substitute gt's products above with your favorite diy products but process and rule of thumb are the same.
