Night Fury
- Jun 13, 2017
- 17
- 1,043
- 745
- Chicago
- Black Type R
Let's talk about this topic, all feedback area welcome!
So what is it? It is a buildup of carbon material on the top of your intake valves (between).
Causes: In my head, a bad design ( pretty much all new engine models), and the absence of an extra injector to clean all that crap inside the engine.
A more elaborated answer, copied from another forum:
To understand what causes carbon buildup, you first need to understand how our engines work. At its most basic, an engine burns two things: oxygen and fuel. In our case that fuel can either be gasoline or diesel. So, an appropriate mixture of fuel and oxygen are needed in the combustion chamber to explode when the spark plug ignites. In the old days, oxygen and fuel were mixed in the carburetor and passed to the engine over the intake valve. In more recent times, a fuel injector sprayed a fine mist of fuel into the intake port. From there the air/fuel mixture passed over the intake valve into the combustion chamber. This was called port injection (you still see this advertised on older GM cars). Port injection was a huge leap forward in terms of both power and fuel economy. You could much more finely control the mixture, and dynamically control the mixture based on what the various sensors were communicating to the ECU.
I'm thinking already on:
Thoughts?
