Car keeps going to accessory mode when trying to start
Bkusza
Brandon
PA
2019 Civic Si Sedan
Hello. Sorry in advance if this has been posted but couldn’t find anything related. I have a 2019 si with 7,000 miles on it. When I get into the car to start it it will only go to into accessory mode Initially. If I push to start again, it stays in accessory mode.
The only way that I can get it to start is by pushing clutch in, pressing push to start, going into accessory mode, taking my foot off the clutch and turning the car back off. After I do this, push the clutch in and push to start my car will turn on.
The first few times it did this I just thought maybe it was me but has happened several times. Thanks
logan5
Keith
Forest City NC
2020 Honda Civic Si Coupe
I would go get this checked out at the dealer. But, of course, it will start perfectly when you try to show them!
yansag1982
Yanick
Montréal, Canada
2020 Coupe Sport 6MT
The only way that I can get it to start is by pushing clutch in, pressing push to start ...
You mean...if you do just that part, your car won't start?
Cause those are the only 2 steps that should be required from you for a succesful start...
if that ain't the case make sure to consult with the dealership for a fix.
Bkusza
Bkusza
Brandon
PA
2019 Civic Si Sedan
Lol of course it will! That’s why I figured I’d ask around first
Bkusza
Bkusza
Brandon
PA
2019 Civic Si Sedan
Exactly. It SHOULD start from this and the first time it happened I was like “eh maybe I was lazy and didn’t have the clutch the whole way in”
After it happened several times after that over the course of a week and a half I think it’s an issue... just odd
Crowe
Eric
NW Ohio
2017 Civic Si
I'm wondering if pulling the battery for a bit will fix whatever is causing this.
Bkusza
Bkusza
Brandon
PA
2019 Civic Si Sedan
I’m going to get it to the dealership as soon as I can. Today it happened again. It took me 5 attempts to start the car before it actually turned over
repeet
Fort Mill, S.C.
jesus7feasts.fyi
'23 BRZ
Sounds the clutch pedal position switch may be intermittent.
