IronFusion
- Fred
- Nov 13, 2016
- 56
- 779
- 283
- Philadelphia, PA
- 2017 Civic Coupe EX-L
- Vehicle Showcase
I installed the app to the headunit a week ago. I was able to pair and put in the pin. Only one time since does it connect.
I have the v2 in the BT device list on the unit, but there are never any available options but "Delete." So I don't think it is connecting to the car.
The KTuner unit shows on the left side of the device list under "Connect" within the app, but it doesn't show when I scan for devices.
Sometimes when I turn on the car the headunit prompts that an app wants to control BT, and I just tap "Allow."
Something odd on the KTuner unit... When I go into the menu and select "BT Pin" I see three options: Disable, Enable, and Enable Advanced. But, tapping any of them doesn't seem to do anything- no submenu or return to the layout.
Before I found out the KTuner doesn't support ELM for OBD Apps, I had tried to pair with my phone and use in some apps. Same behavior- just didn't seem to connect. I could delete the device from paired devices, scan, and re-add with pin, but then no connection happened.
My KTuner is often rather laggy updating gauge, and sometimes just seems to have stopped communicating with the ECU.
I always have my phone BT Paired and Connected with the headunit. Both the TunerView Lite app and the KTuner Firmware are up to date. No broken pins on the OBD Plug.
Anyone experience this? Is my unit going bad? Something I missed?
Side question... Are the full set of readings available in the full TunerView app? I kind of wanted to put mass flow readings on the Headunit.
