alpine86
Can we increase LED DRL light output by changing led bulbs inside?
10th gen civic here.
It's a little more Involved than that even. One would have to replace the drivers for a more, power-hungry COB. After that would be the matter of heat abatement. As of now, Halogen is still more effective.The short answer is yes, you can, but it will be exceedingly difficult to do without badly messing something up. The long answer is that you will have to bake your headlights to pull them apart, pull out the circuit board, pull off the SMDs, re-solder new SMDs, then put your lights back together and pray they still work. If you were even thinking about doing this, I would highly suggest buying an extra set off ebay so you don't ruin your own.
