Can I limit how far my hatch opens?
BrandonSmith
The Greatest Country on Earth
2016 Civic EX 2.0L
OrchidFc3
Holly
New Brunswick Canada
2017 Civic Type R, 1996 ITR, 1992 SI
MadMage
Dan
Arizona
2020 Type R
I would go the strap or rope route for the short term. Then look at shorter struts. Can you estimate how much shorter you want them perhaps by marking the desired position with tape and then fully opening it and measuring the distance?
zenren
zenren
Brenden
Missouri
2018 Civic Type R
I will probably find a way to hold it part way open and then measure it
bikejog
ny
Install an infrared cut off switch so that when the hatch is up, it cuts off the infrared beam thus cutting off power to the garage door opener.
zenren
zenren
Brenden
Missouri
2018 Civic Type R
I don't think that would work in my garage, that would put the beam right where your head would be when you go through the walk in door, plus I would have to park my car in pretty much the same place
bikejog
ny
Install multiple sets in X and straight patterns like those in Mission Impossible movies. Or there must be some other types of proximity sensors that might work. I know, not the best solution. lol...
shadow
Philippines
Check out this site for struts.
https://www.ebay.com/str/strutyourstuffhere
The site teaches you hot to pick the right length and pressure. You'll have to figure out what rod ends work on our car.
I got a couple of struts from them for a carbon fiber hood of another vehicle. It has been a few years and the struts are still holding up pretty well.
