newskate9
- Stephen
- Oct 23, 2018
- 33
- 259
- 231
- PA
- 19 Type-R, 16 Honda Pilot Elite
Hi all, I'm sure the first thought many of you had was "anyone can explain tuning - you're just changing the engine's settings in the control programming". Perhaps this is true, but grab your popcorn and hear me out. As with my other recent post, this is for fun and learning.
Starting point: I'm KTuned using TSP File. I got a recall letter saying they need to change some stuff. You've seen the letters that have been posted. I asked what to do and was given the coaching: Flash to stock, unregister the device from the ECU, execute the recall, re-register the device to the ECU, reinstall the tune, have a nice day. All of these steps make sense. However........
What is tuning, and how does it work? Follow me here: If tuning is a set of 2 columns of numbers or conditions represented by the input or output signal name (i.e. RPM for turbine spool up, gear), then the tuning file can contain as many or as little variables as needed, listed in the 2 columns. I think. Flashing another tune, or back to stock, just puts the inputs/outputs back to factory settings and life goes on.
So, in the development of the different tunes, the expert just pulls the variables he/she wants, puts in new numbers or conditions, then flashed the program to the ECU. I'm guessing the list of ALL variables is included in the flash of the ECU as the ECU is erased during the process. The TUNE is changing only those variables the author wishes changed, and all other are left alone. I'm also guessing this is NOT programming per se, meaning the program for how the car operates is NOT changed, only the information the program uses to do its job. I'm also guessing the program is IN the car and cannot be altered, or is chosen to not be altered by the tuning process. Hence the word "tuning".
Confused yet?
Now the recall is received. Does / Can the recall change the settings? Or the program? Or both? If it does, how does the tuner (the actual person) know this and account for it? The question then, can tuning undo the impact and fix of the recall in any way. OR - can the recall change the program to the point of what the variables mean (the Honda engineers would know), add new variables, delete current variables, rename them, etc. Again, if any of these conditions are created, how do the tuners at KTuner or TSP know this and alter their tunes? Do they even need to?
Sorry for the length of the note. I know the questions make sense. Maybe I'm over thinking this but I assume the tuning world and Honda would work in harmony with each other to some point. Any input or comments are welcome.
Confused yet?
