I have been emailing Corey. $1089 + shipping ($80 for CA) for the race radiator.I guess we have to go through Corey to get the race version radiator and how much more was it? I only see the street version on their website.
@fatherpain Was there a main reason you switched from Koyo to PWR? With Acuity reverse flow hoses on both will you notice a better difference with PWR?
Compared to the Koyorad radiator, is the C&R radiator thicker or thinner?
Very helpful. Wonder if the C&W or Koyorad radiator would fit if you have aftermarket IC piping
Same thickness... but denser and more columns. 110 vs 80
It didn’t fit well with my HKS ic and piping. I think it has to do with the angle of the hot side piping on the HKS. I run the C&R intercooler now and will probably upgrade the charge pipes to PRL.Very helpful. Wonder if the C&W or Koyorad radiator would fit if you have aftermarket IC piping
I hate this sight everytime i think ive finished my spread sheet build you guys come up with finding new companies with new parts.... Can you drop the link for this one I can only find the AUD and not this one.... ughC&R/PWR would be lighter and more efficient while maintaining low IATs and consistent boost pressure. You’ll be able to continually do pulls with the C&R whereas with the PRL you might have heatsoak issues and not be able to shed the heat.
Email Cory to order. [email protected]I hate this sight everytime i think ive finished my spread sheet build you guys come up with finding new companies with new parts.... Can you drop the link for this one I can only find the AUD and not this one.... ugh
I want to give some more insight on this.
Received a help request via PM from a forum member who just had a C&R race radiator installed and developed a coolant leak. The shop that did the work is closed until Monday so he was in a bind.
This fellow Type R owner lives just a few minutes away, so had him bring the car to see if we could fix the problem.
Raised the car and removed the under tray and plastics to access the radiator.
The source of the leak was the lower radiator hose connection. Suspect due to a design issue with the C&R radiator.
It’s difficult to see, but it appears the base of the hose connector terminates right on or next to the horizontal weld joint.
The upper portion of the hose hits the weld bead (blue arrow). This results in a 3/4” gap on the lower side (red) that cannot be made up and becomes a potential leak point.
There’s a chance It leaked due to a sloppy shop install... but there wasn’t too much adjustment other than the OEM clamp position.
Fixed the leak by adding a 2nd hose clamp. Hopefully that holds. The ideal repair might be to notch a cutout on the hose, but that would require completely draining the radiator
This is the PWR version that Lust and I have. Notice the hose connector sits further down, away from the same weld joint.
Confident C&R will make adjustments to future radiators once this is brought to their attention. But for those that already have these, please be aware.
If have one on order, suggest reaching out to C&R to request they address this issue before shipping.
At the very least, take extra care when installing and consider adding an extra hose clamp.
The weld bead should not be a problem. My radiator has the same welds and location as the one leaking. Radiator hose connections “seal” with a clamp directly behind the nipple on radiator itself. The clamp should be located directly where my finger is pointing.
@fatherpain I would advise whomever you had add a second clamp, to remember both clamps and only have one located directly where I pointed in the picture. I 100% guarantee it will not leak with proper clamp location and proper clamp torque (assuming an adjustable clamp was used). Spring or tension clamps are technically only good for one use (oem ones).
Sorry, had a couple typos in my previous post that I had fixed. “Remember” was supposed to be “remove.”Hey there 17RGuy,
Thank you, that is good to know. If that is the case, I'm not exactly sure why the lower hose connection was leaking so badly. The OEM clamp had been placed closer to the radiator itself.. Approximately in the middle of the aluminum tube.
The car with the leaking radiator was not mine... But am the one that added the 2nd hose clamp to get the leak to stop. The good news is the driver hasn't texted me back, so the leak repair appears to be holding.
Maybe the root cause was a poor install by the shop and not the weld joint as I originally theorized.
Can you please post another photo of that lower hose connection where it contacts the horizontal weld seam?
