MutatedMango
- Mar 24, 2019
- 13
- 488
- 205
- Philadelphia
- '19 Civic Si FC3
Jailbroken on iOS 12? Sick
1400 for the w1?head port and polish is about $1400, and pair with aftermarket valves, seats, spring, retainers, keeper, and valve seal for about another $1300. The head itself cost almost as much as the shortblock . I plan for a lot of crackle and pops, maybe shot or machine fire. And also idle tune to sound like cams, going to pump gas a lot
back to redline though, I donāt think the W1 can bring it to 8k at all, especially with such fuel limit. But reaching 8k is kind of scary as oil would need to flow more and hopefully drivetrain can keep itself together. I wouldnāt like to end up like MAPerformance where they lift off clutch to change gear and rpm blip from 7.4k to over 8k or so. Mis-shift at 8k definitely will throw something mechanical off. Redline is designed for mis-shift at rev limiter
W1 - cheap and easy to replace if my tune/driving destroys it
For $1400 new from 27Won, definitely worth the buy.
$1,400 for W1 from 27Won website. W1 can be rebuildable by them if it breaks out of warranty at a little over half the cost.1400 for the w1?
They actually list for $1,592.71. Sounds like you got a deal.$1,400 for W1 from 27Won website. W1 can be rebuildable by them if it breaks out of warranty at a little over half the cost.
You won't make over 400whp on the W1 turbo without meth and pushing the turbo past it's capacity.A little over 400whp for street fun. Got the 27Won turbo to be installed as well. Itāll be a fun fwd daily driver with the pretty amazing powerband without delay. PnP extra low end torque and more power high rpm . 8K screamer
Weāll see what port and polish can do and if fuel kit is available by the time Iām ready to get my car worked on.You won't make over 400whp on the W1 turbo without meth and pushing the turbo past it's capacity.
Lol good luck. Fuel kit youāll have to put together yourself as Maperformance and PRL have some of what you need. The rest is up to you to get. Fueling is one issue. Turbo is the other. 27Won even says that the limit of the turbo is 30psi and any higher would result in it going boom boom soon. As that is what happened with Francoās turbo pushing over 400whp on W1 with meth @35psiWeāll see what port and polish can do and if fuel kit is available by the time Iām ready to get my car worked on.
Can you let me know how this swap went? I recently cracked my block and I feel like this is my best option to get back on the road and not have this issue ever happen again.Have one here.
Will be swapping this Si shortblock and a Si head. Swapping the L15BA shortblock will require Siās pulley belt as itāll mount starter in different location. But hey, if your motor is already apart, might as well change oil/water pump, timing tensioner/chain while itās the cheapest at that moment for labor.
Iām not 100% sure if everything else can be swapped from L15BA to L15B7 but hoping most of the stuff can be swapped over to new motor so I donāt have to buy parts as I go. People have done Si to hatch and stock ecu works great. Just hoping my port and polish head donāt throw me lean until itās fully break-in.
Any update??Can you let me know how this swap went? I recently cracked my block and I feel like this is my best option to get back on the road and not have this issue ever happen again.
