fitter_here
- Apr 2, 2016
- 3
- 763
- 330
- Ste-Anne-des-Plaines, Quebec, Canada
- Civic LX 2016 Sedan
Did you lubricate your brakes once a year?
No I don't , I learn that here few months ago. I want to do it , I know now it is a must.Did you lubricate your brakes once a year?
Last time I did it, I removed all the rotors and put anti-seized on the hubs, it will be easier to remove when I do a complete brake job.
I use to have Corolla with drums in the rear, I never touch it either
Should you use anti seize or brake lubricant for the pads which contact the caliper bracket?Anti seize compound works great for this
brake lubricant on brake parts that move. Anti seize for the back of brake rotors. I've also never put lubricant between the pads and piston, not sure why ppl do it, never had noise come from there either.Should you use anti seize or brake lubricant for the pads which contact the caliper bracket?
