Civic Disobedience
- Todd
- Nov 4, 2018
- 3
- 60
- 9
- Omaha, NE
- 2017 FK7 6MT (Hatch Sport)
Thanks for that tip! I lubed everything well when I put on the new rotors and pads. I got the PowerStop Evolution Geomet kit from RockAuto. The rotors are coated to resist rust and corrosion--they look pretty cool as well. I didn't feel the need for the drilled and slotted version, especially for my rear brakes. We'll see how it all holds up.After you replace the pads and rotors, one way to prevent this from happening is maintaining and lubricating the pads and calipers regularly. Yes surface rust is unavoidable in some places but it’s usually wiped clean when the brakes are applied. The reason the ring of rust has formed around the outer edge is the brake pad is most likely jammed in the rear pad carrier.
You need to lubricate the tabs where the pads touch the carrier. Also the caliper sliding pins need to be lubricated regularly; super important since this design has the sliding pins mostly exposed.
It’s recommended every B service, but for places that salt the roads, I’d recommend it every A service instead, or at least every time you rotate tires.
