Similar to the Acura rl calipers, you'll need adapter brackets.Hello for everyone. Would you explain
'00 - '06 Lexus LS430
Is it bolt on , or need some thing drill?)
Lexus ls430 are bigger then cts-v brakes.I don’t want very big brakes like CTS-V, but maybe a bit bigger than stock and bolt on.
It’s looks very small, like 260-280mm front brakes, I want some thing like 310-320mm.Lexus ls430 are bigger then cts-v brakes.
What size are your stock brakes?
My car from USA, my2020. Maybe brakes from SI will be better solution.European models already have 293mm front disc and 280mm rear.
The SI or 10thgen accord front brakes are 312mm .You could use those but you cannot get the rotors in Europe.
If you just want better brakes install Sport brake pads and slotted rotors.It improves the braking a lot.And better sporty tires is the best you can do.
Si brakes are a good upgrade for a US 10thgen.My car from USA, my2020. Maybe brakes from SI will be better solution.
but I think left brake pads are making noise when braking, So I ordered brake pads From Acre Japan. and I will replace them once they arrive.*Edit 2022-01-31 the brake rotor was confirmed to be from Nissan Maxima 2008 2014 A35
Edit 2022-02-01 ordered Project Mu Brake Pads Type PS Perfect Spec Willwood 4 Pot #7416 #7420 - F1102 for daily use.
Its very smooth for daily driving and the noise I had with hawk pads was gone as soon as I changed them. I like the pmu brake pads very much and I am super happy with them.
I will probably use the acre brake pads for track use as it seems to be more track oriented than pmu ps pads.
Too bad this isn’t available in the states. Looks like a great economical choice with calipers that are not overly large.I confirm that the Brembo/Renault BBK by K-system.pro with the 324x32 discs for the FK7 are cleared by OZ Ultraleggera 17x8 ET40 5x114.3
Can you weigh the calipers and rotors if you haven't installed these yet?I got the rage brake kit for the front and rear. Super happy with how they came out so far.
I have them on the car but I'll weigh them the next time I service my brakes.Can you weigh the calipers and rotors if you haven't installed these yet?
