Brake Fluid Change to DOT 4, Flush Clutch Also??
Bituminous.R
Andrew
St Louis, MO
2019 Civic Type R, #26556 CBP
I recently bought some DOT 4 brake fluid (Motul 600) and wanted to flush my 2019 Civic Type R's brakes. I later found out that the brake reservoir also feeds the clutch. If I flush the OEM fluid out of the reservoir and my brakes, do I need to flush the clutch as well (I assume yes) but can the clutch run on DOT 4? Is that acceptable?
TopCatCt
Colin
Coventry, England
Civic X Sport
I change my brake and clutch fluid with Dot 4 all ok, usually every 2 years
Benster
Ben
Nova Scotia, Canada
2019 Civic HB Sport 6MT
your clutch master cylinder is basically half a brake cylinder so yes, no issues at all with any dot 3 or 4 fluid, as long as it's not silicone(dot 5). Dot 5.1 is still similar to dot 4 so you can use that as well.
Benster
Ben
Nova Scotia, Canada
why are we bringing a one year old thread back from the dead? :banghead:
oh no!! We're all going to die and overload the forum!!!
Nessism
Torrance, CA
2017 EX-T Civic
Nothing wrong with bring an old thread back in my view. Better than starting a new thread because someone is too lazy to search for info.
I recently bought a pressure bleeder for the brakes. I've used vacuum bleeders in the past but I found more positive reviews on pressure than vacuum so...
Going to tackle the job at 25k miles. That's 5 years for me. I know that some people say 2 years, but in the grand scheme, I think 5 is okay.
