fabrizzio71
- Matthew
- Oct 18, 2018
- 30
- 380
- 272
- United States
- 2018 Civic SI Coupe White Orchid Pearl
I have about 12,500 miles on my Si, and have only tried going WOT recently. I normally drive the car with the boost gauge visible as I like to monitor what’s going on with the engine. The first time I put the pedal to the floor it was in 2nd gear and I was surprised that the boost never went higher than 14-15 psi. I felt that was strange as previously I have seen boost go as high as 18 psi a number of times and 19psi twice. Just this evening, I tried again and did an experiment. I revved to 4,000 rpm in 3rd gear, put the pedal to the floor and held it, letting off before redline. Boost never went higher than 15psi. A little while later I did the same thing, but instead of putting the pedal all the way down I pushed it maybe 80% and boost went up as high as 18psi. I did this several times to confirm and got the same result. I am used to pedal to the floor meaning maximum acceleration, but it seems that isn’t the case here. This is my first turbo car and my first car with drive by wire. I recognize that the computer goes to 100% throttle before the pedal gets to the floor, I have even tested that with the car off but the display on. Why would boost be limited with pedal to the floor? I do have the Acuity Throttle position spaced but it is in position C which I didn’t think would cause an issue. Any insights?
