Shred
- Will
- Sep 9, 2019
- 10
- 486
- 350
- NV
- Honda Civic Type R
- Vehicle Showcase
- 2
It's not just the fuel, if you put higher quality fuel in a USA FK8 you won't have the power gains. They might be able get more aggressive based on the higher quality of the fuel. DP and E is the easiest way to get power, but Phearable tuned a HVI and IC and got 370. The IC does give a bump but the intakes generally don't make a difference unless you go race MAF IIRC.Euro cars only get that rating from the better fuel, lowest places have I'm told is 95 ron, and that's the equivalent of 91 octane in the US. 373 might be possible, but he's not FBO, still the stock airbox too, just a K&N filter. Exhausts don't help the car breathe until much higher power, and the downpipe would need to be larger as well to accommodate. These cars it's widely known the quickest sources of power are either flex fuel (higher octane for the ol boost) or a larger downpipe with a higher flowing cat. You'd most definitely see something like this (from the link you sent)
" Test Results On A Stock Vehicle With Only Phearable Stage 2 Tune: 353 HP 363 TQ on 93 octane "
The higher octane over there could potentially bump it up to higher, but you'd be making that power from some slight timing changes and more boost probably (still new to this so perhaps not 100% sure).
As for this issue, still can't be sure. I don't think it would be a wastegate thing unless your car peaks boost pressure at 6500rpm. Not sure what the shop did to your car.
Keeping air filters clean is important, but I don't think they can get that dirty to choke a turbo.
Massaging dyno numbers is a possibility too of course, especially if the shop isn't giving access to logs.
