cmwalton16
- Feb 12, 2017
- 15
- 703
- 722
- Tennessee
- 2017 Civic Si Coupe ABM, 2016 Civic Touring CBP
I just installed the Boomba Racing Rear Motor Mount this morning, and the install went pretty painless. Pulled the car up on a set of ramps and followed the installation instruction video on their website.
I knew going into this, that it is going to cause more vibrations in the cabin/steering wheel/shifter. When I first put the car in reverse to back down the ramps the vibration was HORRIBLE! Really bad/loud vibrations that I could feel in my seat and everything I touched in the car. When I put the car in drive and go, everything is fine. There are some minimal vibration in the lower RPMs, and coming to a complete stop but this is what I would expect with the mount. I drove the car about 15 mins and then came back to the house. Once I put it in reverse to back up into my parking spot, again with the HORRIBLE vibrations. Has anyone experience this, any ideas? I'm not sure what is going on but I definitely don't like it.
Help!
Update 2/20/17
After about 250 miles with the mount on, the park and reverse vibrations are just unbearable. Boomba replied today. They said their engineers said to torque to 69 ft lbs on both bolts. When I installed it, I had only torqued the chassis side to 67 and the engine side to 45 (it felt like less effort when loosened than the chassis side). So I came home today to see if torquing both bolts to 69 would resolve the issue. When I attempted to tighten the engine side to 69 it wouldn't go higher than about 31 before dropping back down to the low twenties (using a digital torque wrench). I was worried the bolt may be stretching or something compressing so at that point I decided to remove the part. I installed the OEM mount back into the car and torqued everything down with no problems. As you can see in the last picture I added, it was actually the Boomba mount that was compressing based on the indentions you can see.
I am dissatisfied all around with the product.
Help!
Update 2/20/17
