Blew out tire sidewall, some questions...
rwsmith123
Richard
Raleigh, NC
There was a good size rock on the road I didn't see and ran over it at around 30mph and it blew out the tire sidewall, other than a little nick the rim doesn't appear to be damaged:
Honda Civic 10th gen Blew out tire sidewall, some questions... IMG_20201225_141504292
I don't have road hazard insurance. I assume that's not going to be covered under the normal tire warranty?
These are the original Continental ContiProContact tires, they have 16K miles on them have been rotated once at around 9k miles and all the tires have about 7/32" of tread remaining (original depth was 9/32). The damaged tire was on the driver front. Should I get just the damaged tire replaced or would it be better to replace both front tires so they are more evenly matched? I have no complaints with the ContiProContact so will keep the same brand.
yansag1982
Yanick
Montréal, Canada
2020 Coupe Sport 6MT
Same thing happened to me with my previous civic coupe and I ended up just buying 1 tire to replace the damaged one. It was fine.
hondabandit
hondaman
ny
2019 sport hatch
After 2 blowouts, I ditched the continentals, and never had problems since.
JasNeo
Jordan
Massachusetts
2018 Si Coupe
Most newer passenger car tires usually have about 10/32nds, so getting just one should be fine. I would however recommend rotating the new one to the rear to have the 2 fronts be the same. Even tho it's not much of a depth difference it could cause a bit of a pull.
