SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
USB Music Player FAQ ( maintained by Scopesys)
Note: This 1st Post will be updated to reflect new information as it becomes available.
(9/18/2018)Note: This 1st Post will be updated to reflect new information as it becomes available.
What is the biggest size USB drive that you have managed to get to work reliably on the 2018 Honda head Units.
So far I have tried:-
1 Gig USB 2.0 "ebay - cheap- china drives" -- either unrecognized, or audio skips
16 GB USB 3.0 Cruzer Glide - works very well - no issues -- fast
64 GB USB 3.0 Cruzer Glide - Forced to FAT32 format (= Bigger cluster size than standard) - Not recognized
9/19/2018
Formatted 64GB drive to FAText. Put into Car. The used head Unit to reformat the USB drive. Now correctly formatted to FAT32 by Android OS.
Drive can be read.written to by PC (Xp & W10), and the audio file are now visable in the Car, and play !!
Next step: Try same method with 128Gb & 256Gb drives
32 GB USB 3.0 Cruzer Glide (Standard Fat32 format) --- works well - no issues - fast
32 GB USB 3.0 Micro Center (generic) $4-$5 (Standard Fat32 format) --- works well - no issues - fast
=============================================================The only info I have found from Honda is "not all USB drives are compatible"
The only info I have got from my Dealer "We are not computer people"
(9/18/2018)
SORTING FOLDERS and FILES on USB drive for cleaner display on Honda HU
WARNING: Be carefull... using CMD prompt with care.
Make 100% sure you are executing these command on your USB Flash Drive, and not on any other drive on your computer !!
Be particularly careful using the "del" command (Delete command)
YOU DO THIS AT YOUR OWN RISK - if in doubt DO NOT do it !!!
So you have put 1000's of songs onto your USB drive, but when you come to play them, TWO Problems
(1) Some don't Play
(2) The Folders and files are a total mess.. no specific order .. can't find anything.
Solutions: (1) Some don't Play
You need to remove (delete) any non playable files from your USB drive
The only files that will play are mp3, mp4a and wav ( may be others ?)
So, how do you FIND , and then delete any non playing files ?
(a) Find any files that are not mp3
Under dos cmd, go to root of your USB drive, and use the command
dir /s /b /a-d | findstr /v /r ".*\.mp3" > found.txt
This will give you a file called "found.txt" which will list all the non mp3 files.
(b) Then look at found.txt in Notepad, and make a note of any non-playing file types .. ie .avi .wma etc
Should not be many as you have removed any .mp3 files from this listing
Then type
del /s *.avi
to delete all .avi files on the current Dos selected drive (Your USB Drive)Do for all found non paying file types.
Finally delete the found.txt file ie del /s *.txt
NOW all you should have on your USB drive just playable files.
Solution (2) Folders and files are in Random order
To sort Folders and files into Alphabetical order on the Flash drive (so that Honda USB Player will display them in Alphabetical order) , you can use the windows Program "DriveSort"
https://techmadeplain.com/2014/how-to-sort-music-flash-drive-car-stereo/
(Full pictorial instruction on above web page)
Now, when you put your USB Flash drive back into your car, at least everything will be sorted Alphabetically, - Both the Folders, and the files within those folders
(9/20/2018)
Confirmed: There is a 700 Folder max limit on the 9" Head Units USB player.
If each ALBUM is in its own folder, and each album has approx 10 mp3 songs, then 700 albums is about 32GB.
32GB is also the max size that Windows allows a fat32 format, although other formatter can format Fat32 onto bigger drives, and windows can then still be able to read and write to that drive.. just that windows cannot format a drive to Fat32 on a drive bigger than 32Gb, without using some non microsoft formatting program.
The point being, with the 700 Folder limit, and using a folder per album, there is NO POINT in trying to use a drive greater than 32GB, as only about 32Gb would hold accessible music.
CONCLUSION: If you want more than 700 albums, use multiple 32GB drives.
