Alvi_l96
- Alvin
- Dec 6, 2019
- 14
- 5
- California
- 2018 Civic Si
Hi all, long time lurker, first time poster here if I recall correctly. I drive a 2018 Civic SI with an RV6 catted downpipe, mishimoto intake, and I'm currently running a TSP stage 1 tune. As of late I've been getting a strange turbo whine. The turbo seems to be spooling as fast as it did before, but now there is an audible 'whine' that changes pitch with the turbo spool. Nonetheless, I can already assume that these are telltale signs of an approaching turbo failure. So, Looking at all of my options, I'm planning on upgrading to a W1 turbo from 27won and getting it e-tuned by Derek Robinson. Two very well respected names in the 10th Gen community. Now, with all that hooplah out of the way, my question stands. Is upgrading to a bigger turbo safer on the engine (ie. rods/pistons/crank etc.) than having a smaller turbo? I did a bit of research and found that the TSP stage 1 tune and a properly tuned W1 setup produce similar torque numbers (around 280-300wtq), however the torque for the W1 setup is shifted higher in the rpm range. Allegedly this torque at higher RPM's is safer for the engine, which leads to the hypothesis that a bigger turbo is safer for an engine than a smaller turbo at similar torque levels. Can someone with some more experience confirm and explain this? I tried searching the internet but haven't had much luck in way of a thorough explanation.
