Best tire size?
U.S.C
Bo
So cal
instagram.com
2019 Civic Hatchback
I am looking to get new tires and this is what I have now. 215/40/18.
I don’t want a huge tire tho is that my best option?
They are 18x8.5
I am looking to get new tires and this is what I have now. 215/50/18.
They are 18x8.5
You have 215/50-18's on 8.5" wide rims?
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Your current set is a little stretched but the thick sidewalls are helping a little bit:
https://www.civicx.com/threads/new-here-introduce-yourself.76/page-166#post-612987
Default tire width for 8.5" rim is 245mm and you can also go -1 at 235mm. So 245/40/18 and 235/40/18 sizes will both work. Shouldn't be any rub on 8.5" rims and stock heights. Your offset is +35? May want to go 235/40 if lowered.
Play with the following to stay within +/- 2% from OE tire diameter/circumference.
https://www.wheel-size.com/calc/?wh...-18X8.5ET35&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
U.S.C
U.S.C
Bo
So cal
instagram.com
I meant 215/40/18
TypeSiR
On a Twisty Road
I meant 215/40/18
As you're looking to replace the current tires. So only focus on what's the best fitment for the 18x8.5 rims, hence go with 235/40 or 245/40.
U.S.C
U.S.C
Bo
So cal
instagram.com
I’m a complete noob with tires lol. So would that be a bigger side wall than what I have now?
Giltibo
Gil
Alliston ON Canada
'08 Accord Coupe 5MT. '18 Civic Sport Touring 6MT (Both Red!)
The OEM tire size on the Civic 8.5X18" wheels (Sport and Si Coupe and Sedan, Sport / Sport Touring Hatchback) is 235/40-18.
_dc_
Toronto, Canada
2017 Civic Coupe Touring
The OEM rim width is 8", not 8.5". A 215 tire should not be put on a 8.5" wide rim. Minimum should be 225 but optimal is 235 or 245. You can use the OEM tire size of 235/40-18 on a 18x8.5" rim.
